Question about Lexmark X4580 InkJet Printer
Need to install soft ware on my laptop, but do not have a disc for lexmark x4580
  • 820 Answers
Online support for Lexmark X4580:
http://support.lexmark.com/index?page=answers&startover=y&question=x4580&productCode=LEXMARK_X4580&locale=en&segment=SUPPORT&userlocale=EN_UK
Select the tab Downloads. Click the download according to the used operating system. Download now on the next page.
After the file is download click the execute file.
Files will unpack in the directory as showed while preparing the installation.
A wizard will pop up to guide you through the installation.
Guides are under the Publications tab of the support site:
pdf files:
Guide getting started
User's guide
html link:
User's guide for MAC
Posted on Sep 27, 2009
  • YourZEN
    YourZEN Sep 27, 2009
    Note:
    Do not connect the printer until the installation wizard tells to do so.
Soulvisitor
  • 1113 Answers
SOURCE: Lexmark 1270 printer
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC. (For more information Click Here)
· Download the correct Vista driver for your model. (Click Here)
· Install the driver on your PC. (Click Here)
If you are facing issues, scanning using your All in One Center, Here is an alternative.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
DRIVERS LINK
Posted on Dec 08, 2007
SOURCE: Need help in connecting my lexmark x4550 to my
http://www.lexmark.com/lexmark/site/home/
go to this link and enter the make and model number
you may have to go thru the menus but you can find installlation software and support for your printer. I found the software for our lexmark here at work at this site ... they sent us a primter without any CD in the box , i didn't want to wait for themn to ship a new one. It was very painless.
TDEx Chic Phoenix AZ
Posted on Apr 21, 2009
ginko
  • 19396 Answers
SOURCE: I HAVE A LEXMARK X 1270 I NEED THE SOFT WARE TO
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Posted on Jul 25, 2009
Roop1980
  • 228 Answers
SOURCE: Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Posted on Oct 01, 2009
Testimonial: "Thank you. I was on the phone with Lexmark a whole hour last night and they couldn't fix it. This corrected the problem immediately! You are a Wiz"
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: I NEED TO SET UP MY LEXMARK X4580 PRINTER TO MY
    you will need to install the printer software compatible for windows 7 available in the manufacturer's website for download. Check the version of your operating system if you have 64-bit or 32-bit OS. To check go to start > right click computer > click properties. Download the proper driver package by going to this link : http://bit.ly/dq2FVh . Click on Microsoft tab. Download cjq3500-4500Win7en.exe for 64-bit or cjb3500-4500Win7en.exe for 32-bit. Install the software. Hope this helps.
    Posted on Mar 09, 2010
    Install x4580 without cd
    You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
    Jul 20, 2012 | Lexmark X4580 InkJet Printer
    How do I configure the lexmark x4580 to identify my computer?
    Try to insert the installation disc into the computer hard drive and run the install setup. Simply follow the instructions on your computer screen.
    You can also try the downloadable Lexmark X4580 printer driver from the Lexmark website at http://bit.ly/pOdfTQ. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
    Jul 12, 2011 | Lexmark X4580 InkJet Printer
    I NEED TO SET UP MY LEXMARK X4580 PRINTER TO MY NEW LAPTOP THE PRINTER IS WIFI AND THE LAPTOP ISWINDOWS7
    Mar 07, 2010 | Lexmark X4580 InkJet Printer
    I have a mini pad laptop, and need to download the manual for the lexmark x4580 printer
    What does one have to do with the other?
    Lexmark x4500 manual:
    http://images.lexmark.com/publications/pdfs/2007/3500/v2103618_en.pdf
    Sep 27, 2009 | Lexmark X4580 InkJet Printer
    Install disc
    Here is all the software and drivers from Lexmark's Support and Download Page.
    http://support.lexmark.com:80/perl/support/support.cgi?ccs=229:1:0:331:0:0
    Just Download and Install the drivers and software for your operating system and your printer should be good to go.
    Dec 29, 2008 | Lexmark Office Equipment & Supplies
    Hp deskjetf4100 all in one series
    returned to shop with product, static buil up on the laptop!!
    Jul 20, 2008 | HP Office Equipment & Supplies
    Trying to get my printer working
    go to Lexmark X2350 - Drivers and Downloads and select your Operating System:
    http://search.lexmark.com/printer/US/en/19M0000
    Nov 24, 2007 | Lexmark X2350 All-In-One InkJet Printer
    Software for all in one x1185
    Here are a couple of links that have the driver software
    for the Lexmark X1185:
    http://www.driverstock.com/Lexmark-X1185-driver-download/12-26-5473/index.html
    http://members.driverguide.com/driver/detail.php?driverid=187004
    Nov 23, 2007 | Computers & Internet
    Lexmark X4580 InkJet Printer Logo
    113 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
