Question about Alarm & Keyless Entry System for Honda Vehicles
Car alarm goes off in the night only. How can I
Car alarm goes off in the night only. How can I disconnect the alarm?
    Scholar:
  • 51 Answers
1. make sure no one is trying to steal your car. 2. it should be a simple fuse that you can disconnect 3. if not, cut the wires to your horn (you wont be able to pass inspection if you do this)
Posted on Feb 09, 2010
Alarm goes off middle of night for no reason. viper model 5704V
u seem to hav a computer/module system issue--get a data stream run that shows values so a good tech can decyfer-need factory gear not a 20dollar scanner--stay away from dealers-------1st tho try anothr remote or changn batts--or even disconnect car batt fora minute
Nov 07, 2013 | Cars & Trucks
Fuse diagram
It may be easier to just disconnect the battery at night. You could even buy a disconnect switch.
The siren is powered by a 10 or 15amp fuse number 12, but you would still have the hazard lights flashing. That is a different fuse. The actual keyless entry and alarm module gets power from several sources.
Jun 17, 2013 | 2001 Hyundai Santa Fe
Hyundai alarm
I was having the same issue and just disconnected the hood switch cabling completely. This not only solved my 3 am alarms for no reason but also allows the car to arm the rest of the system, by beeping and flashing lights when arming with the keyfob.
Apr 26, 2013 | 2009 Hyundai Elantra
2003 Toyota Highlander Alarm Goes Off ?
problem could be in door central locking system or body ecm.let dealership check it out.
Jan 03, 2013 | 2003 Toyota Highlander
MY CAR ALARM IS ULTRA SENSITIVE
In such a situation it is best to dis- arm the alarm as it can give false signals and give you sleepless nights.
Even if the sensitivity is set to low it can cause alarm as when a large truck moves the vehicle.
Alternatively you can use the new generation alarm system with surveillance which can connect to a mobile phone if some one tries to enter your car.
Jul 04, 2012 | Audiovox - AS-9903 - Six Tone Car Alarm...
Alarm Malfunctioning - 2004 Sable
Have your battery checked for shorts. Mine was defective on a new Lincoln. Same problem. Even sat in it at 18 degrees one night to appease neighbors whom my alarm woke up.
Check connections at every possible point if the battery tests good.
Get up 30 minutes before alarm usually goes off and see if neighbor has loud car or slams his car door. Motion sensors can set it off too.
Aug 17, 2009 | 1998 Mercury Sable
Car alarm
when you lock it do you use the keyless remote or key turn manually...
guaranteed fix...go to dealer and have both car and key reprogrammed
Jun 30, 2009 | 2003 Hyundai Tiburon
Alarm problem on my 2001 elantra
This alarm system can only be 'disarmed' using the keyless remote programmed for this specific vehicle. Press the "Unlock" button on the keyless remote -- this resets/disarms the alarm system. If you do not have keyless remote for this vehicle, get one and have it programmed at a Hyundai Service Center. Problem solved.
May 11, 2009 | 2001 Hyundai Elantra
How do i disconnect the alarm
find the horn and look for a wire then cut the wire that goes to the alarm NOT THE HORN WIRE
Apr 15, 2009 | Mazda 626 Cars & Trucks
Alarm & Keyless Entry System for Honda Vehicles Logo
266 people viewed this question
Top SMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a SMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
