Question about Garden
Murray 22'' 6.0 hp gas lawnmower engine dies right after start up.
I have a Murray 22'' 6.0 lawnmower and the engine dies right after I prime it and start it up.I replaced the spark plug but that did not help.Any suggestions? Larry
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
I would start at the float in the carb: Sometimes they will get a hair line crack fill with Gas and will act just as you describe. The float can not float.
Posted on Oct 06, 2013
Try changing the fuel filter. or air filter
Posted on Oct 08, 2011
  • 472 Answers
SOUNDS LIKE YOU NEED A FULE FLUSH AND CARB KIT
Posted on Sep 30, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Primer bulb collapsed
Slightly unscrew the gas cap and see it the problem goes away.
Many times the Gas tank Vent clogs and this will cause the engine to create a vacuum in the gas tank until the engine can't draw in the gas .
Jul 15, 2013 | Garden
Murray select hp
Mathieu. It sound like you have overfilled it with oil. Drain most of it out the leave it level. A lawnmower will run better with it not being overfilled. Clean the spark plug and heat it gently to completely remove traces of oil. John
Jul 02, 2013 | Garden
I have twin 135 hp Yamaha outboard engines. Neither engine will start when cold.Putting small amount of gas into air intake and engine starts, engine starts fine when hot. Choke solenoid working
just like a car before the car start the fuel pump shoots gas in the carb or a lawnmower you gotta prime it all the gas that was in the carbs when you shut them motors off has done evaporated check your fuel cells see if there is a hand pump to prime the carbs unless its electric fuel pumps either way them carbs have to be primed
Dec 22, 2012 | Motorcycles
Lawnmower has been in storage for 6 months. Has new good gas, and gas is flowing to carb. However, engine will not start without priming carb with gas, then runs until primed gas is exhausted. ...
this is from a post i just did for anothe engine but i think it applies to you also.
get a product called START. this stuff is amazing it has solved all my engine problems including a couple like yours. any wal mart should have it. add to your gas and the longer it runs the better it runs. i am telling you it is worth the 6 bucks. i had a 4wheeler that never ran right, always had to half choke it. even though i cleaned the carb twice. added this stuff and by the time that tank was gone it was running like new. if that doesnt take care of your problem then it needs to go to the shop Now your situation i know is dirt or varnish in the carb i have had this problem also. and start worked for me on that also. mix it in the gas and keep it running even if you have to keep priming it
Nov 12, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Garden Logo
1,595 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
