Question about Whirlpool Duet GHW9150P Front Load Washer
Water leaking from front door of washer only on Delicate Setting
I have a water leaking problem from the front door of my washer, which is only isolated to the Delicate and Handwashing settings. I can see a stream of water dripping down the front of the washer. Why??? Is there a easy fix?
Thanks
  • 61 Answers
Rotate the rubber seal on the door
Posted on Sep 28, 2009
When set on delicate cold/cold water, it starts to fill with cold but switches to hot water after a few seconds
Sounds like you've got the hoses switched, and the cold water you're feeling is just what is in the hot water lines until the lines get purged. Try filling on the hot setting and see if cold or hot comes out; my guess is you'll get cold water on the hot setting.
Nov 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dishwasher is leaking water from the front door
The water inlet level setting could be faulty and thus "overfills" the washer with water. The water level is senced via a plastic tube feeding an ajustable switch. Sometimes the plastic pressur sence pipe gets clogged and water level is then not correct. The switch can have burnt contacts and might need replacing.
Jan 23, 2010 | Dishwashers
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from front door after cycle is done
If your washer is upstairs it's probably the washer drainpipe or the piping in the walls. Go look.
Oct 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Leaks on Delicate but not on Normal.
Appears to have been the drain holes below the rubber drum flange. My wife cleaned in there for the first time after our speaking to a lowes sales person who owns one as well. When I monitored the next "delicate" load with the front panel off and after cleaning, there was no sign of water anywhere. Hope this was the solution. My wife also mentioned the loads (on delicate) came out damper than the norm but this time it was much drier. Wonder if delicate cycle may fill the washer higher than the normal cycle.
As a footnote we mentioned an occasional musty smell would occur and the same sales person said to not only leave the front door ajar but also open the soap drawer. When I checked the service manual I noticed the unit has a vent hose which vents into the soap drawer. All makes sense when you consider a front load is much tighter sealed than a top load.
Jun 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak at door
Check carefully for a small tear in the boot or it came loose from the frame.
Eric
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer has a water leak coming from the bottom!
usually this is the front seal around the door they do crack with age. you will have to pull the front of the washer off to change it any appliance parts co. should be able to get you one
May 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
328 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
