Question about Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
My heater fires up after 5 seconds and then dies out.
    Problem Solver:
  • 17 Answers
Locate and clean lens on fire eye. If heater will run with fire eye wires connected with a jumper then replace eye.
Posted on Oct 14, 2009
Pool heater comes on and gas enters unit for about 5 seconds and then the gas shuts off. natural gas
This could be the flame sensor. If you can look into the firing chamber there should be a steel rod about 5" long that dangles into the gas fire jets. Turn off the unit. If you take the fire sensor out and gently rub it with steel wool and replace it, it may start working again. If it does, great, but order a new fire sensor and replace the old one when it comes in. They are very cheap.
May 05, 2017 | Pool & Spa
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
Why is this Pool heater making a very loud whistle sound after heater is fired up.
sounds like a leak in the air stack or if coming from gas valve need new gas valve
Aug 28, 2014 | Sta Rite Pool & Spa
Water heater is not firing up
Faulty gas valve,contact a gas safe engineer to replace.
Sep 27, 2017 | Water Heaters
R55 reddy heater takes 5 seconds to fire
I SUGGEST U GO TO THE FOLLOWING WEBSITE:
http://www.reddyparts.com/
HERE U WILL FIND THE INFO U NEED.
Dec 20, 2009 | Heating & Cooling
Hey my heater when i turn on is the fire for a 5 sec and the fan start work then it die
Check the air filter the fuel level, fuel filter and the fan tightness, this should rotate smoothly.
Dec 15, 2009 | Desa International ReddyHeater® R115DT...
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
318 people viewed this question
Top Reddy Measuring Tools & Sensors Experts
jdthefixer
Matt Olenzek
Matt Olenzek
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
