Question about Canon PowerShot SD890 IS Digital Camera
Images appear to be distorted - Canon PowerShot SD890 IS Digital Camera
Why am I getting pictures with curved edges edges
Hi Ian
What you are suffering is something called barrel distortion which causes images to appear spherised or "inflated". Barrel distortion is associated with wide angle lenses and typically occurs at the wide end of a zoom lens. The use of converters often amplifies the effect. It is most visible in images with perfectly straight lines, especially when they are close to the edge of the image frame
the way to solve it is to try not use the end of the of the zoom of your lens. Above 20 mm you should be fine. If this is not possible then you can correct the effect in programmes like Photoshop
Hope this helps
May 09, 2014 | Sony Cameras
Distorted images
Hi Dong,
i think problem is with your tuner section.
please try with av input with dvd player.
if it works fine you need to repair your tv .go for the good electronic repair shop.
regards.
nuwan.
Jan 10, 2014 | Samsung LN32A330 32 in. LCD TV
Lines appear in picture
Sound like a problem with the CCD sensor; this isn't a job that you could solve yourself. Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value.
If this defect occurs, the signal is not output from the CCD correctly when in shooting mode, which results in symptoms like the following in captured images. These symptoms can be confirmed on the LCD monitor. The same symptoms may also occur in recorded images.
* images do not appear
* images appear distorted
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Sony service. I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Good luck.
Sep 16, 2011 | Sony Cameras
All of a sudden, my pictures have a pink splotch running vertically across the center of the picture. This is happening more often than not, and I can also see the splotch on the image display when I am...
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. A problem has been discovered in some of the CCDs used in Panasonic, Fuji, Sony and Canon digital camera and digital video camera products that causes images to appear distorted or not to appear at all. And the says apologize for the considerable inconvenience this represents for your customers. Along with our respectful apology, we would like to advise our customers of the details of this issue and our policy for handling it, which are as follows.
The Malfunction:
Among the CCDs used in the affected products listed above, it has been confirmed that, especially under high-temperature/high-humidity environments, the internal wiring may come undone in some places.
If this defect occurs, the signal is not output from the CCD correctly when in shooting mode, which results in symptoms like the following in captured images. These symptoms can be confirmed on the LCD monitor. The same symptoms may also occur in recorded images:
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; this, isn't a good new, but hope helps to solve it.
Jun 14, 2011 | Panasonic Cameras
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Images and letters appears distorted
Convergence IC failure is the main cause if the distortion youre seeing is like a 3D image.
Jan 02, 2010 | Televison & Video
My camera will play back images but distorts new images
Hi!
It's faulty CCD (imager). Ask Sony if they change them for free there.
Tom
Jul 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
CCd failure
This is a good blog on CCD failure; http://www.teleplancamerarepair.com/camera-repair-blog/post/images-apear-to-be-distorted-e28093-images-do-not-apear-e28093-Might-be-the-CCD.aspx
Goes into the distorted images you describe, explains why it fails, what it looks like and how to fix it.
While the images actually look cool it's a real drag when it happens to your camera!
Other things that happen is the images do not appear, or show with a magenta hue, or green tint.
Mar 31, 2009 | HP Photosmart 945 Digital Camera
Discolered, blurry images in viewfinder and LCD
i am sorry to say that your camera has a broken CCD.you need to get to replace the CCD with a new one
Jun 25, 2006 | Nikon Coolpix 5700 Digital Camera
Why do straight lines in my images appear to be distorted?
Lens characteristics can cause straight lines to appear bent. This phenomenon, which is called "lens distortion," is normal and does not indicate malfunction of the camera. Such distortion tends to be more pronounced when the camera is at an angle when you point it at the subject.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Canon PowerShot SD890 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
