Question about Maytag Neptune MDG5500AW Gas Dryer
Drum not turning - Maytag Neptune MDG5500AW Gas Dryer
    President:
  • 1,304 Answers
Belt
part number 33001777
sub to
33002535
Posted on Oct 03, 2009
Konica c2253
One of the drums is unable to turn, pull each one out. check them, physical turn drum make sure you turn them correctly, and use the edge of the drum not just put fingers on any part of the drum, might. one at atime hav to get a color drum and black drum they are different and replace the black if not that the replace the color one
Jun 23, 2014 | Konica Minolta Bizhub C360
Minolta cs pro ep 1085 errore code c0010
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it.
Nov 23, 2013 | Minolta Office Equipment & Supplies
I have a minalta cs pro ep 1085..when I tried to take copy the paper jumed and errore code apeared (c0010) ,, any help will be greatfull
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it. Hope this works for you
Hope this works for youH
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer does not start. Drum does not turn by hand. Only makes a sound when switch is turned on.
If it is a sound like a loud hum, the motor is either fried or something is jammed preventing the drum from turning. It could be something like a sock. You just have to open things up and look around carefully, especially around the outside of the drum.
If the noise is a more normal one but the drum is not turning, check that the belt is around the drum and not broken. Some drums are just fairly hard to turn by hand, partcularly if the belt is still around the drum.
Sep 19, 2009 | Dryers
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum will not turn.
Sounds like you've got something stuck in between the drum and tub the best way to check is through the heater at the rear of the machine. Could also be the motor or drum bearings have seized if its the drum bearings there's usually brown oil coming from the back of the drum. Take the belt off to see if either the drum or motor can be turned manualy. hope this helps.
Dec 12, 2008 | Zanussi F1045W Front Load Washer
Dryer Motor won't always start Model FSE747GES
Too much drag on the Drum. Try lubricating the rollers that the drum turns on. Check the belt tensioner pully...lubricate that as necessary. If Drum still turns very hard after this then take belt off of motor and try turning drum. If drum turns easily then replace motor.
Nov 24, 2008 | Frigidaire FDE336RE Dryer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
64 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
