Bosch Nexxt  300 Series WFMC2201UC
Problem for Bosch Nexxt 300 Series WFMC2201UC
It show an error of E:04
By kimberlyj5 on Sep 27, 2009
it show an error of E:04
how do I clean out the pump and where is the pump? the door will not open, even after putting it on the drain cycle
Solution #1
posted on Oct 09, 2009
Somewhat Helpful)
laptop377
Rank: Apprentice
Rating: 75%, 1 votes
First unplug the machine. Next locate the 8" round plastic circle near the bottom right front corner of your washer. Rotate this until the pinhole is at the very bottom then the plastic cover should pop off revealing a black pump. The front of the pump will unscrew and water will gush out. Carefully reach in and fish out any stones or glass that may be causing problems. Then screw the pump back together plug the machine in and try another load. If all goes well replace the plastic cover and smile.
Was this helpful?
Yes
No
Popular Solutions for Bosch Nexxt 300 Series
Questions and Unsolved Problems for Bosch Nexxt 300 Series
Do you recommend Bosch Nexxt 300 Series WFMC2201UC?
Answer
Answer
Machine is level but viberates on spind cycle, Have to hold machine down. one month old, used one... (More)
Answer
I have a Bosch 300 front load and the rubber is torn and has a hole inside the door.
Answer
Hello, I get a E:13 error code and the door will not unlock. Any ideas?
Answer
We have a two year old Bosch 300 Nexxt washer. It has started working intermittently. It might... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
