Question about Frigidaire FGF378AC Gas Kitchen Range
The oven temp is cooler than the temp read.How can I adjust it?
    Problem Solver:
  • 12 Answers
Pop off the oven knob and look at the back of it. sometimes the are two screws that you can loosen and fine tune your temp settings. if the temp is way off i would say you need a new thermstat. its a little bit off work but you could definetly do that yourself and save some money on repair costs.
Posted on Sep 27, 2009
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Why does my oven thermometer read less than the temperature the oven is set at?
An oven doesn't go to the temp selected. That is the average temp. If you set it to 350, it may drop to 300, then to 400, but will maintain an average of 350. Without knowing your model #, it is hard to say. Some have anticipator (that anticipates the temp and controls the heater and the thermocouple that is trying to keep the temp steady. Some models have an adjustment at the oven switch (rear) that can be adjusted for temp up or down.
Oct 20, 2014 | Ovens
Oven temperature is inaccurate and takes a long time to heat to proper temp. I have replaced thermostat with no improvement.
To Adjust the Thermostat
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 12, 2011 | GE J2S968SHSS Dual Fuel (Electric and Gas)...
Bosh double oven. Temp is 100 degrees cooler on top oven, any ideas? both on bake mode
The fact that top oven is 100degrees less than bottom is no relation between the two; they are controlled by independent stat controls and if the only way you know if the temp is correct, is to set a temp (such as 350 degrees) and put a thermometer in that oven to see if the thermometer is with in 25degrees of the control settting. You need to do this for the bottom oven as well to see if it is aslo within 25degrees of the setting. then you make adjustments for each unit independently. If the controls are mechanical (knob), then the adjustment is within the control (usually by removing knob and serching for a small screw). If the controls are electroonic, then you need to search the circuit board to see if there is adjstments mounted on the board. Goodluck,Macgivor
Jan 31, 2010 | Bosch HBN 455 Stainless Steel Electric...
Oven cooks 10 degrees cooler. How can I fix it?
select bake
set the oven to 550 degres
hold the bake button until you see the temp go to zero
push the temp select up until it changes in five degree increments to the desired bump up in temp you can raise it or lower it up or down by 35 degrees in five degree increments, once you have the desired adjustment it will revert back to normal on the controls screen readout
check the oven temp and adjust as necessary, this info is available in your users manual as well.
Jul 14, 2009 | Maytag MER5775Q Electric Kitchen Range
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 | Ovens
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Adjust temp level of the oven .. model 34ja-5tkxw
Press the bake key.
Adjust temperature to 550 degress.
Press the bake key again and hold it for 3 seconds.
The temperature +/- should appear.
You can then adjust temp +/- 35 degrees.
Mar 24, 2008 | Magic Chef CER3725AA Electric Kitchen...
Frigidaire FGF378AC Gas Kitchen Range Logo
64 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
