Question about HP 2025 20.1" Flat Panel LCD Monitor
Can not get the menu for monitor setting to stop rolling. Will not leave screen.
    Sergeant:
    Champion:
  • 289 Answers
Maybe one of the buttons is stuck? a short circuit in the button is definite to cause that... i shocked my last monitor and it started doing that. I had to buy a new monitor, because my tech couldn't fix it because it was arcing
Posted on Sep 27, 2009
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
My monitor menu on my samsung syncmaster 731n keeps popping up on the screen and I cant get it to stop
this is a normal condition for that kind of monitor, because it was design only with Samsung syncmaster 731n in which the old model. The reason why it always popping up is because it always adjust the setting of the images. The only way to solve this problem is if this menu appears again you only press the reset button there at the left side of the power button.
Aug 31, 2011 | Samsung SyncMaster 720N/731N
Used the cd that came with the monitor. Now size, pixels, etc. are wrong, so much so that it cannot be used. How do go back to pre-cd-use? Thank you AOC 2036S Serial # Q81A8HA267758 LCD 20 inch...
If You really can't read anything on the screen this wont help. If you can make out a bit, then right click on a vacant area of your screen, then select "properties". On the Display Properties Menu, select "Settings", then select "Advanced". This will bring up a menu that shows your Monitor and Display Driver info. Select "Display", then select "Properties", then select "Driver", then select "Roll Back Driver". This will restore the old driver for the Display. If this doesn't help, go through the same menus again, and on the "Monitor and Display" menu select "Adapter" instead of "Monitor", and roll back that driver.
Best of Luck
Dec 08, 2010 | AOC 2036sa 20"TFT LCD Monitor
Rolling screen
1. Try it on another computer to rule out the video card.
2. if it persist your going to need to repair the monitor or replace it now all you need is the control board $25 bucks on ebay. Now if you do not know how to replace this then I would leave it to the experts around $90 bucks parts and labor.
Thanks and please do rate this with the thumbs above. thanks
Feb 13, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Resolution notice keeps popping up every thirty seconds or so. very annoying. this happens only when using cd rom game diablo. wants me to change to 1280x1024, which my computer is set at now. otherwise...
When you load the splash screen of Diablo enter into settings. Make sure you have the game set to the screen resolution you want.
For the system. Open display properties. Click Settings, click Advanced, click Monitor. (Most games require 60 hertz) to run correctly. Change your monitor to 60 hertz. Than click the Adapter tab. Click list all modes. Move the slide bar to your normal screen res with 60 hertz. Click ok at every screen as you back out od display properties. That should stop your game from popping up.
Feb 26, 2008 | Niko 1920R Monitor
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Osd locked
I had precisely the same problem... I depressed the Menu Button for about twelve seconds or more and the menu actually finally popped up; and does so now every time I depress Menu! Hope this works for you.
Big Jim
Dec 30, 2007 | HP vs15 15"LCD Flat Panel Monitor
Monitor problem
Sounds like you have a coincidental hardware failure. The reset button usually sets the monitor to factory default which is good in most uses. A rolling pattern on the screen is occasionally due to electronic interferrence such as a mobile phone in the vacinity. As you say your screen is fading completely suggests a hardware failure and nothing to do with your pressing the reset. If your monitor is less than 3 years old (standard screen warranty) I would contact the manufacturer and they may send you a new one.
Sep 06, 2007 | Acer AL1717 17" LCD Monitor
HP 2025 20.1" Flat Panel LCD Monitor Logo
43 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
