Question about Carver Audio Players & Recorders
I have a A-753x magnified current 3 channel power amplifier that requires a "on/off" switch. This was Carver's weakness in this amplifier, I am looking to replace the switch but having a hard time trying to find a supplier for these switches.Any help would be appreciated.
I've owned four of the amps from this series and in no way are the power switches the weakness in this product. (A-220, A-753x, A-760x and an A-500x.) If yours is "broken" it had to be an environmental issue or single unit anomaly if yours hasn't held up. I don't get why people are asking your about the output characterstics of the amp because I don't see anything about THAT in your question. Go to Ebay.com and search for "Sunfire Amplifier" and look for a gentleman who's taken over "Rita's" Carver repair service. They both were affiliated with Bob Carver (you can also search for Bob himself under the seller name "audioshopper") and someone can direct you towards somebody who might (MIGHT) have a NOS power switch available. There have to be a ton of switches that will perform the same function, they just might not be a perfect Chassis fit. There's a solution to your problem. If nothing else, straight wire the switch on and plug the amp into a power strip.
Posted on Feb 08, 2015
  • 21 Answers
SOURCE: Amplifier problem
You may have a blown channel. Check for fuses inside but I don't think that it will help. Repair if the channel is dead is not worth doing as the amps value is probably lower than repair cost.
Posted on Sep 03, 2007
  • 899 Answers
SOURCE: Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Posted on Nov 03, 2008
  • 4234 Answers
SOURCE: Peavey 8.5c amplifier. One channel dead. In
FIrst of all, in bridge mode there is only one channel. The "bridge" means that you combine the two channels together to get a single more powerful amp. The swollen part is probably nothing. Sometimes the plastic caps cup like that. Unless there is a specific problem with the amp, don't worry about it. Try placing the amp into stereo mode and testing each channel. If both work, there is no problem with the amp. If for some reason you need repalcement capactors, contact Peavey directly. They supply replacement parts.
Dan
Posted on Mar 19, 2009
marsrover
  • 682 Answers
SOURCE: Right channel cutting out.
connect right channel speakers to amp left out if the problem fixed you will have a problem in amp itself.
if the problem remained you will have a problem in speaker itself test first with new cable and second with speaker cabinet,
Posted on Apr 14, 2009
  • 185 Answers
SOURCE: Carver power amplifier Pm1.5, 110 acv accidentally plug in to 220
magnetic field supplies are different than conventional types, check that the thyristor is working properly
Posted on May 27, 2010
How do I connect my bose equalizer to my pioneer amplifier
The manual is at Bose.com.
In any question regarding connections the exact models of all parts in the scenario should be defined.
"Pioneer amplifier" is not unique nor revealing. Integrated amplifer? Power amp? Tape Loops available? Pre-Outs? What's involved as a preamp?
The key thing to know is that any amplifier channels driving 901's must not drive other speakers as the Active EQ severely modifies the Line Level source input. If the EQ (or any sound processor) is used in a Tape Loop on a modern multichannel digital-audio-capable AVR, ONLY 2-channel analog sources will function when the Tape Loop is engaged; and all downstream speakers will be affected by the processing. That's par for the AVR course.
Bose 901 use in multichannel applications (which I have) will require access to Pre-Amp outputs for the chosen channels (likely the Front) and you will need to get a separate amp for the 901's, placing the EQ in series with the chosen amplifier. I currently drive mine with a Carver MT-200T.
Sep 20, 2011 | Bose 901 EQ1915 Home Equalizer
Bridging Carver AV860X
AV860 is coming up with bupkus.
Bridging instructions are usually marked on the back. Typically, move a switch and connect the pair's positives to the speaker.
Mar 31, 2010 | Carver PM950 Amplifier
Feb 23, 2010 | Audio Players & Recorders
My turntable connect to Carver Preamp, I bought a
If you can hear music with the volume up, but like it was turned down low (from the power amp), then yes there is something up with it. If it's the same on both left & right channels, then it's something common to both. For instance the power supply, or an IC that has both channels going in it.
If however the power amp does produce sound normally with another device, then either the turntable has a fault, or the pre-amp has, perhaps on the pre-amp inside it for the cartridge.
Dec 16, 2009 | Yamaha P-2500 Amplifier
Eurovox Max V -codes required for basic channels on Chorus Dublin
Then you don't need codes. It won't amplify the signal and if it's weak it won't receive all the channels.
Sep 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
I have a carver M 1.5 amp rt. channel is out.
Carver designs in general are not easy to repair. I would recommend that you send this unit into a Carver authorized service center. The likely problem is the output transistors, but the driver circuits and predrivers are not simple designs and if there is a problem there, it could effect the outputs. Tracing this will require equipment and schematics that I don't believe are available on the net.
Dan
Sep 04, 2009 | Carver PM950 Amplifier
Best amps for bose 901
You need an amplifier with at least 200 wpc to get the most out of your BOSE. Look into getting a NAD, ADCOM or CARVER amplifier. I prefer CARVER myself. I am running a CARVER M-500T(251 wpc) on my 901's and they sound incredible.
Aug 25, 2009 | Bose 901 VI Main / Stereo Speaker
Apr 14, 2009 | Audio Players & Recorders
Carver PM350 ampliefier needs fan and fan motor replacement
These are not expensive even directly from Carver. Call them up for the current pricing and availability.
Dan
Mar 24, 2009 | Carver PM950 Amplifier
Nov 02, 2008 | Audio Players & Recorders
197 people viewed this question
Top Carver Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
jeff5may32
Are you a Carver Audio Player and Recorder Expert? Answer questions, earn points and help others
