Question about Kenmore Kitchen Ranges
My kenmore stove was supposedly converted to propane when i bought it . the range works fine but the oven flames are very high and yellow and it makes a terrible smell what is wrong?
    President:
  • 1,304 Answers
Its not properly converted
sounds like the forgot to flip your gas vale head pin
Posted on Oct 05, 2009
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
OVEN FLAME TOO HIGH ON A A GE CONVERTED TO LP
You should have a pressure regulator between your stove and your propane bottle. It's probably delivering too much propane at too high of a pressure to the stove.. If you don't have a regulator, THAT would be your problem. A regulator set to too high a pressure makes flame too high and flame may even try to blow itself out. I've remedied this by taking a small cover off the center of the regulator and adjusting a screw.. (Not all regulators can be adjusted.) If adjusting isn't possible, I'd suggest a new pressure regulator (for LPG). Note: A regulator for LPG is NOT set up the same as a regulator for natural gas.
Oct 28, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
I have a kenmore gas stove 790-75711890. my oven ignitor was only glowing. so i thought not enough gas i removed pressure regulator and blow thur it then reassemble. still not liting. i bought new oven...
On the top of pressure regulater is a removalable piece that fits one way for nautral gas and the other way for propane i am wondering it was installed upside down afer ya reassambled it, accidenttly setting it to propane which defeintly will cause that
Aug 22, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Propane coversion of kenmore 790 gas range
Most gas stoves are shipped for natural gas .You need to check the orifice on each burner to see if they are for natural gas or propane.If you ordered propane the stove should have been shipped with the orifices.They may be in a bag with your stove documents.
tk46
Jul 13, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
What could be wrong with a gas stove hot point(2 yrs old)that has lots of black in the oven when using and also black on bottoms of pans when using burners on top? it just started doing this...
The flame is 'yellow tipping'. This means there is incomplete combustion and will leave black soot on everything. Did you recently start using propane? If so the stove will need to be converted to propane use, or the incoming gas pressure is too high. You may need a gas professional to check the gas pressure.
Jun 07, 2008 | Kitchen Ranges
Changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Apr 08, 2007 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
194 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
