Question about Sony Televison & Video
Sony rdr-gx360, stuck on dvd 1, cant change to dvd 3 to use remote and i have tried everything it says in manual.
  • 70 Answers
SOURCE: DVD stuck in player SONY RDR-VX 515
Take the lid off by taking the 2 to 4 screws out of the sides of the unit to get the disc out.
Posted on Feb 19, 2008
SOURCE: Remote is Stuck in DVD 1 mode
solution to the problem is as follow:
1. press down the "ENTER" buttom and then press the "1" number buttom for about 5 seconds
2. press down the "ENTER" buttom and the "3" number for aboput 5 seconds.
This should reset the recorder to the DVD3 mode
Good luck.
Posted on Oct 05, 2008
  • 3 Answers
SOURCE: sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Posted on Dec 20, 2008
SOURCE: dvdRDR-GX360
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
pgmadhav
  • 145 Answers
SOURCE: Sony RDR-GX360 unlock
Region lock is given to kill piracy. Please help to kill piracy.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Hi I have a sony dvd recorder gx360 that will not work with my remote. When try, it displays dvd 2 on front of the panel. I think its locked, how do I unlock it?
You have got the wrong remote code!
I have copied this from the manual....
Set the command mode for the remote so it matches the command mode for the recorder you set above. Follow the steps below to set the command mode on the remote. A Hold down ENTER. B While holding down ENTER, enter the command mode code number using the number buttons. Command Mode DVD1 - number button 1 DVD2 - number button 2 DVD3 - number button 3 C Hold down both the number buttons and ENTER at the same time for more than three seconds.
The correct "default" for the remote is DVD3!
The full manual is available free on this website:
http://www.manualslib.com/manual/228795/Sony-Rdr-Gx360.html?page=23#manual
Mar 08, 2016 | Sony Televison & Video
I have a sony rdr-gx 360 with no remote and tey are very expensive to replace. can i get a universal remote for this?
Many universal remotes will operate (with some limitation) most SONY products including DVD recorders. You can maybe find a universal remote either on eBay, remotes.com website (or similar addresses) or perhaps your local electronics store has them in stock - and those are relatively cheap to buy off the shelf. It would then be a question of figuring out and entering the right code for it to (minimally) control the unit. The best universals are the all-in-one types although a 4-in-1 works just as well. Elaborate function remotes will cost more than the basic ones.
Feb 21, 2011 | Sony RDR-GX360 DVD Recorder
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
Sony gx360 stuck on dvd1
press and hold enter on remote... then, while holding the button (more than 3 seconds) press and hold down the number 1. after 3-5 seconds, things should return to normal.
Nov 10, 2009 | Sony RDR-GX360 DVD Recorder
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
1 Hold down ENTER
2 While holding down ENTER, enter the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Disc tray will not open
I've not found one, no, but I have managed to strip the machine down, get the disc out and rebuild... I guess this is too late for you but it's simple enough if you're still trying.
Mar 04, 2009 | Sony RDR-GXD360 DVD Recorder
Have sony rdr-gx360. no manual to show how to work recorder or format cd.
Try this - You will need remote.
After you have recorded video... (if you eject disk all will be lost)
- Push "Setup"
- Now push "Edit"
On left hand side it should now show "Finalize disk".
I also lost manual and took a few minutes to find.
Dec 25, 2008 | Televison & Video
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
Dec 17, 2008 | Televison & Video
DvdRDR-GX360
Dec 13, 2008 | Sony RDR-GX300 DVD Recorder
Will not reset to the easy menu as to change DVD 1 setting
Try putting fresh batteries in the remote and then:
1. Push and hold "Enter"
While
2. Push and hold "1"
Keep them down for about 5 sec.
Your remote is now in mode 1 and will talk to your RDR VX-525.
In the EZ Setup are you can change the unit back to remote command mode 3 if you wish. The remote will stop working again, but you just have to repeat the setps above using button "3" instead of "1".
Aug 17, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Televison & Video Logo
222 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
