Question about Hitachi 53FDX01B 53" Rear Projection Television
Need assistance hitachi 53" lines of resolution are out of sink will not fix with remote or manuel.  Picture is bleeding red, shadow or ghosting red. email add is jasmine827@hotmail.com Thank you for your time and assistance
    President:
  • 4,402 Answers
Http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 18, 2007
Magic Focus button will not line up picture. Red and green colors shadow images.
The tv have a problems known as a convergence picture problems it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes of these problems.The tv convergence board must have to repair like replacing like 2 STk covergence ICS and some or all of it resistors too.To fixed the tv convegence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 53SWX01W Distorted red lines and shadowing.
that is from a bad video board..try turning it off to reset the values, but I'm not confident it's recoverable without some serious technical help
Apr 27, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
Ghost shadows in multi colors
u need to replece the convergence ic , this are 2 big black piaces # stk392-110 or stk392-150
Apr 12, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
How do I aling colors: the red and blue colors are not align making the tv look distorted.
On my Hitachi there's a convergence button on the front panel. Press that button which will give you red & blue lines. You have to use your remote to converge (align) those lines to correct the picture. If the lines won't converge I've been told it could be a bad convergence IC & tech is needed to fix...could be approx $300 to fix.
Jan 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Color ghosting or shadows
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
replace the conv ic,s stk392-110 and ck for any bad rest in that circuit
Apr 14, 2008 | Hitachi 53UDX10B 53" Rear Projection...
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Blue shadow or ghosting on screen
  1. First try Magic Focus
  2. if this will not fix problem
  3. then you have a convergence problem
  4. You will need the Converg. Kit
  5. X480295 part number
Nov 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53FDX01B 53" Rear Projection Television Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
