Question about Dryers
I have a Kenmore 76975 electric Dryer, The drum will not rotate but the belt is still intact what could be the problem?
  • Dryers Master
  • 8,404 Answers
The belt is fine (properly tight) and the drum doesnt turn, Id trake a look at the pulley on the motor.
You must remove the top and front to get to this.
I presume the mortor is running ...
Posted on Sep 27, 2009
The dryer drum does not rotate. I have a Kenmore electric model number 110.62622101. It blows hot air but drum does not rotate
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 15, 2011 | Kenmore 62622 Electric Dryer
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
I have a kenmore 27 inch electric dryer that when you push the start button it sounds like it starts but the drum doesn't turn. What could this be?
A clear indication that your dryer belt is broken is when the dryer drive motor runs but the drum does not rotate. A new belt is relatively inexpensive from several online or a local parts vendor, but installing it can be a bit frustrating since the dryer drum usually needs to be remove to install a replacement belt. Access to the interior of the dryer is usually necessary. For Maytag (and some Kenmore) models, the front of the dryer can be easily removed (two screws below front contour) by pulling out on the bottom of the panel and rotating up to release the top clips. Once off, place to the side, then remove four machine screws from the front drum/lint filter assembly, then remove by pullling out. Once off, place aside. Remove drum by lifting up and pulling out on drum (since the belt is broken it will not provide any resistance). Once removed, inspect the motor pulley arrangement noting the belt routing path around the motor pulley, belt tensioner, and the drum. Inspect the drum for belt wear marks, noting approximate location on drum where belt rides. Install replacement belt by routing through pulley arrangement (ridged side of belt rides againt motor pulley), then "hang" the belt on the interior backside to enable reaching the belt after reinstalling the drum. After placing the drum edge on the rear rollers, lift the front of the drum up into position, working the belt around the drum into the drum groove. Once the belt is in the groove, the drum should stay in position without lifting from the front. Check for proper pulley routing, taking care to avoid routing the belt OVER the tensioner belt keeper, i.e., route the the belt under the belt keeper to avoid belt riding on the keeper and failing prematurely. Install the front/lint filter assembly. As you manually rotate the drum, reach along the top and side of the drum and gently pull the belt out of the groove and into its normal ride position. Install the front panel, plug the unit in, start and check for proper rotation of the drum.
Oct 04, 2009 | Kenmore Dryers
Drum does not rotate
The drum rotates due to a belt that goes around the drum and is driven by a small motor. The most likely answer is that the belt broke. This a common problem on an older dryer. It is relatively easy to replace the belt.
Feb 01, 2009 | Kenmore 62602 Electric Dryer
Drum will not rotate in LEW0050p Dryer
hello is the door making the switch if thats ok check wires see if any are loose if thats ok .at the bottom of the machine next to the motor theres a part callled a capacitor its got 2 wires coming off it this can stop the dryer rotating i hope this help
Jan 28, 2009 | Whirlpool LEW0050P Electric Dryer
Whirlpool dryer heats but the drum doesn't rotate
There is usually a large belt that goes around the drum to turn it ...it is either fallen off the motor pulley , broke .....or the motor may be gone in it ....not sure if there are any fuses for the motor on your dryer .
If you can tip the dryer over the bottom is usually open and you can see the motor and belt from there
Jan 09, 2009 | Kenmore 64952 Electric Dryer
Kenmore Dryer: Drum will rotate, but only manually
Best way to confirm if it's a belt/pulley problem is to remove one of the access panels on the back of the dryer. For many models, it's on the bottom, right hand side. Open it and look inside. You also use that access panel to put a new belt on since it can be difficult to do from the front, having to reach past the drum. But if everything is intact, then you should be able to "rethread" the belt around the idler pulley and onto the motor pulley.
Here's a common diagram:
If the belt is OK, but came off the pulley, then most likely, your idler pulley has too much play in it or the spring has lost tension and isn't holding it securely. I'd put the belt back on. If it comes off again, then look into replacing the idler pulley and/or spring.
Oct 20, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Dryers Experts
