Question about InFocus LP70+ Multimedia Projector
Not able to adjust color and tint - InFocus LP70+ Multimedia Projector
  • 2,236 Answers
If resetting the setting to factory default doesn't work, you need to replace the colorwheel. you can get one through an infocus authorized service center, or send it to one for repair. try www.avsolutions.com. they're pretty good.
Posted on Oct 21, 2009
My 19 in. is not possible to adjust the color, tint and sharpness bars. It skips, what will I do to make the adjustments?
If the set is running in some type of component mode or digital component mode, there is no adjustment for color or tint.
Sep 21, 2014 | Dynex DX-LCD19-09 19 in. LCD TV
The colour on the screen and the colour of the prints is not the same. Do you know what the problem is and how to fix it?
mlatham990,
First I would make sure that you have not run out of one color of ink, which will make the colors look funny. This is the most likely problem and can be solved by replacing the cartridge. If you print a test page it should be obvious if a color is missing.
If you are absolutely sure that there is not a color missing then the following information may be helpful.
There is no adjustment for the relationship of the colors at the printer. Depending on the monitor you have you may be able to go into the menu and adjust the tint, which is the relationship of the three colors, but generally monitors use an RGB signal and you cannot adjust the relationship.
If you can adjust the color tint I would print out a test page, or something with the color which is wrong, and then compare the colors on the page to the color on the screen while adjusting the tint to make the two match.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 26, 2010 | Epson Stylus Photo R340 InkJet Printer
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
Aug 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
A lot of green tint in the picture
Hi, what you do is unscrew and take off the grill, take off the black board behind it. You will see a little box for adjusting RGB you will adjust the screen rgb to get the tint to go away and have a perfect color then you will adjust the focus for sharpness. (reset the tv to factory settings before doing this so that your tint, color, brightness and everything else is in the middle.
Oct 17, 2008 | Televison & Video
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Mag monitor dx17t tint adjust
adjust color and tint by pressing buttons on your monitor
Feb 09, 2008 | Computers & Internet
InFocus LP70+ Multimedia Projector Logo
70 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
