Question about Dryers
Ignitor won't ignite after working for 2-5 min
My gas dryer ignites and goes on and off for two ignition cycles before making a noise. During the noise the igniter heats up (glows) but doesn't ignite. When noise stops the ignitor cools off (no glow). This pattern repeats itself for the duration of the dryer cycle. Thermostat? Coil?
  • Dryers Master
  • 8,404 Answers
Your fuel supply is OK?
If the igniter comes on and you have fuel, there is no problem ... for some reason you dont have fuel, seems to me.
Did you check the gas valve(s). There nay be several.
If you have gas and the valves are on ... you have an electric (gas relay valve) problem.
Posted on Sep 27, 2009
Viking VGIC oven burners ignite but cycle off repeatedly temperature rarely gets to 300 after 30 minutes. If igniters ignite is problem elsewhere - like bad bi-metal valve? Range and broiler work OK,
There is a sensor that detects the oven temperature, it must be defective and sending a signal that oven is at set temperature and this shuts off the gas valve.
Nov 02, 2016 | Viking Kitchen Ranges
My Maytag Model MDG3500BWW gas dryer will ignite and burn properly for about 30 seconds, then the igniter will glow bright orange, then shut off without igniting the gas. It will continue this cycle of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][
Aug 07, 2011 | Maytag MDG3500BWQ Dryer
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Dryer won't light. Igniter glows, then turns off,
heatman101
Jun 25, 2011 | Frigidaire Dryers
My gas dryer will not heat, but makes a funny buzzing type noise as if it is trying to heat/ignite. On the air dry cycle, there is no noise at all (also no heat, but that's ok). After letting it run for...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 19, 2010 | GE Profile DPSB620GCWW Gas Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Could be a coil...but I have learned that it usually is the ignitor...
heatman101
Sep 02, 2010 | Roper RGX4634KQ Gas Dryer
I have a Kenmore gas dryer, model 80. The burner ignites but turns off fairly early during the cycle. It gets warm for a few minutes, but ends up not drying anything. I am trying to narrow down which parts...
Make sure the lint filter and the exhaust duct are clear all the way to the outside vent. If the gas cycles once and then does not light again the thermostat may be defective. If the gas lights but then goes off when the ignitor stops glowing then the secondary coil on the gas valve is bad. (This ignition cycle may continue to go on and off but the gas will not be lit enough to provide enough heat for drying.) The coil assembly can be replaced.
Aug 12, 2009 | Dryers
Dryer won't heat
i only ask this because you mentioned the loud noise are you almost out of propane, is it a pop sound or ?
Jun 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
76 people viewed this question
Top Dryers Experts
