Question about RCA R52WM24 52" HDTV Projection Television
Volume quit working...it sticks all the way at the bottom, it looks like it will move up and it just sticks and goes back all the way down.
  • nicbue Sep 27, 2009
    Sent me to a website to watch different shows....how is that helpful?
  • RCA Master
  • 8,457 Answers
Check for crack solder in speaker connections,or the sound board is dead.Might even the remote,
Use the manual control volume on the right see if it work manually.
Take the remote apart clean the circuit board little alcahol with a Q tip.
Posted on Sep 29, 2009
When i move my look stick up it goes down and when i move the stick down it goes up
Try going into the options and seeing if there is a Reverse Y axis option. Toggle that until you have the controls the way you want them.
Jan 06, 2014 | Activision Call of Duty 4 Modern Warfare...
Tip
How to fix Volume issues in PSP Portable
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
on Feb 13, 2010 | Video Game Consoles & Games
I also have a Sony STR-D365. Volume control works intermittently as well as right channel. Works if I "wind" the volume control up and down a bit and then goes out again. I reset it and no change. Any
There is a wiper on the back of the volume control that varies the resistance through the switch to control the volume. When you move it back and forth you are scraping the oxides off the switch and making it work again. I suggest you either get some contact cleaner and spray the control from inside (where the wiper is) or just change out the switch.
Jan 10, 2013 | Audio Players & Recorders
Controller not working. On Call Of Duty Black Ops, whenever I move the bottom analog stick up, I look down.But If I move the analog stick down I look up.
Go to the game's controller settings and select which configuration suits you. Don't set it to inverted if you are not used to it.
Hope this helped you!
Rate my answer if you appreciate it.
Sep 09, 2011 | Microsoft Xbox 360 Controller
New Holland DC 100 Dozer starts and runs but won't move. Bottom left warning light is on and can't find out what it is, there is no symbol on it. Guy who was running it said it was working fine for a few...
WE HAVE NEW HOLLARD DC75 IT WON'T MOVE FOWARD OR BACK BRAKE LIGHT STAYS ON AND SAFTY LEVELER WORK JOY STICK SAY IT IN FOWARD OR BACK BUT NOT MOVING WHAT TO DO?
Feb 17, 2011 | Garden
My Tivoli Model One makes a loud screech/buzz noise
I had the same problem and was able to repair it quite easily. Only thing needed is some basic soldering skills.
Problem description:
  • Suddenly a quite loud and disturbing (scratch/screech/buzz) noise appears.
  • Sometimes the noise is gone but it reappears sooner or later.
  • Changing volume or radio band / input (am, fm, aux) does not affect the noise (even on volume turned down all the way).
  • The signal coming out of the Headphones / Rec Out plug is not affected.
Cause:
  • Cold solder joints
Solution:
  • Unplug from mains
  • Remove back panel (the two black screws next to the plugs in the center). The back panel sticks quite firmly, so it might help to remove the front panel first (the 4 screws in the corners) and carefully press out the back panel from the inside. (The other two (silver) screws are used to attach the transformer to the back panel) and need not to be loosened.)
  • On the circuit board at the back panel locate the plug that goes to the speaker (is says "J2"). Check the solder joints. In my case, looking closely, I could see that they're not good anymore.
  • Renew the joints by heating them up and applying some fresh soldering tin. I also renewd the joint from the wire bridge next to the plug. Just check the other solder joints on the board.
In my case afterwards the problem was gone and the device is working properly again.
Apr 03, 2010 | Tivoli Kloss Model One AM/FM Radio
My volume dont work is there anyway i can troubleshoot it or restart the whole thing?
Feb 13, 2010 | Sony PlayStation Portable (PSP) Console
Volume
I think this problem is a program generated problem, i mean your normal program is being damaged or invaded by viruses. Since a typical windows xp os works well if not threaten by other programs. One solution that i can see best is for you to have an updated antivirus program in your PC. After having an updated antivirus program clean your computer by it, then Reinstall your driver softaware for your Windows media player of if you are using different software other than windows media player pls. reinstall it.
P.S. If this helps you solve your prblem please rate me. thanks!
Jun 23, 2008 | LG Audio Players & Recorders
Ds lite
WHEN I PUT MY DS ON IT GOES OFF
Jun 14, 2008 | Nintendo DS Lite Console
Car Stereo Volume Goes Up and Down Erratically
prolly buy a truck and a amp from this century
Oct 05, 2007 | Car Audio & Video
RCA R52WM24 52" HDTV Projection Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
