i have a satellite 5205-s703 that has bluetooth capabilities yet when i try to hook up my new bluetooth mouse i can't get my computer to search for the device. It tells me that i cannot use the bluetooth service center because bluetooth is turned off? how do i turn it on
Normal
0
Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth
Devices window. Insure batteries are installed.
Press the Connect Button on the Keyboard
(Usually located on the under side of your keyboard) this allows Windows to see
the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To
Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device
Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and
click Next.
Windows will generate and display a Passkey. Type the Passkey specified on the Bluetooth
Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if
you make a mistake, you can backspace. You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back
and click Nextagain.
Once the Passkey is entered, the Keyboard should be
connected to the computer. Finish and follow any on screen instructiond.
Hope this helps.Bud
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your...
(More)
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your criteria. It costs less than $65.00 and is easily connected to replace a wired keyboard and mouse.
I have been using two of them for years now, and have never had a problem with them.
They eliminate excess wires, and work like a charm.
How do you get dvi output to a tv using a PC with this keyboard - there does not appear to be the...
(More)
How do you get dvi output to a tv using a PC with this keyboard - there does not appear to be the normal function key or one of the main function keys with a screen icon or similar?
