Question about Bunn NHB Coffee Maker
The bunn nhb developed cracks in the area where the coffee tray slides in andleaks water when brewing
  • 189 Answers
Please call customer service with the model and date code and we will be happy to assist you with this issue.
Posted on May 19, 2010
Bunn nhb disassemble
Most likely is that the seal between the water reservoir and the tank is leaking. Not uncommon. If you can find a replacement seal go for it, otherwise the old one can be made serviceable by coating both sides with a thin bead or layer of clear silicone. Allow to cure for 24 hours before powering the coffee maker back up.
Apr 23, 2014 | Bunn NHB Coffee Maker
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
My bunn nhb makes a continuous "boiling" sound even after coffee has brewed.
Check with Bunn and see if there has been a recall. I did in Canada and they sent me a new machine complete with some Tim Horton's coffee! http://www.bunn.com/
Good Luck!
Nov 26, 2011 | Bunn NHB Coffee Maker
Have a Bunn NHB. I cannot get more than 4 cups of
I work for BUNN. Has your issue been resolved? The rocker arm is inside the pour in bowl (where you pour in the water for brewing). To get to it you have to take off the entire top lid (not just the spin lid above the pouring area). That can be removed by lifting it up and then you simply snap it back on when you are finished. Hope this helps.
Jan 03, 2010 | Bunn NHB Coffee Maker
Our bunn coffee maker is leaking and we don't know why. is there something we can do to find the problem and fix it ourselves?
Is it leaking from the front or back? If its leaking from the basket area, try cleaning the channels where the basket slides in and out. If its leaking from the fill area, check for cracks.
Nov 09, 2009 | Bunn NHB Coffee Maker
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
I HAVE A BUNN COFFEE MACHINE THAT IS SUPPOSED TO BREW 69 OZ OF COFFEE AUTOMATICALLY BUT IT IS BREWING MORE HOW DO I REDUCE THE AMOUNT OF WATER ITS BREWING. IT IS AN S SERIES
Inside of the front cover is a brew timer dial turn this counter-clockwise a little bit, then try brewing another pot. re-adjust as needed. Just watch where you put your hands in there.
Oct 24, 2008 | Bunn NHB Coffee Maker
Cracked plastic
Yes- this is a very common problem with the Bunn home coffee brewers. However, there are no replacement parts available. Your only hope to get a replacement pour-in tray is to get ahold of yopur local Bunn repair center and see if they have a machine that broke down for some other reason and rob the tray from that. You can get a list of Repair centers in your area from www.bunn.com
Oct 04, 2008 | Bunn NHB Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Apr 05, 2008 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
59 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
