Question about Frigidaire GLTF2940ES Front Load Washer
Err code e10
Cycle starts then stops and displays err 10 efo
  • 2 more comments
  • vettie Dec 24, 2007
    i have the same problem what is it?
  • klalaa Apr 24, 2008
    I start the washer and then it stops and beeps with e10 displaying. Anyone know what is happening or what I need to do?
  • dj1lerner Jun 22, 2008
    THE ERR CODE E 10 SHOWS UP IT SEEMS LIKE THE WHOLE CYCYLE GOES EXCEPT THE SPIN.
  • Anonymous Jan 04, 2009
    My washer starts but somewhere in the cycle I get an E10 error code; If I push the door and hit the button it starts back up, I usually have to do this several times during the cycle once it first comes up; but strangely, it works fine sometimes...
It is a water problem. Check the filters on the hoses on in the back of the washer. This happened to us and that fixed it.
Posted on Feb 17, 2009
    Sergeant:
  • 271 Answers
It sounds like your brushes are gone you need new brushes in the motor
Posted on Jan 05, 2008
My washer keeps popping up with EFO in the display window.? What does this mean and how do I fix it/
E10 error is water inlet hose clogged. Screens should be cleaned out. Hot and cold. If you can't do it yourself get someone to help you.
Good luck.
Feb 21, 2015 | Frigidaire Affinity ATF6000F Front Load...
E10 code
on wat ,your head e10 ,what?
Jan 17, 2013 | Washing Machines
I am getting a EFO then E10 error message after I start a load of clothes...which means I have to cancel the load.
E10/EFO error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Feb 07, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
E10 error and Efo error
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!
Nov 24, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Err 10 message on Fridgidaire front load washer
The E10 error indicates a long fill error meaning the machine thinks it took to long to fill with water.
            We recommend u to check that the drain tube is now stuck to far into the stand pipe and possible causing as siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow.
             u can hook the drain hose off, forcethe  water through it with a water hose, unclog the stinky mess and  hook it back up again and  work it.. tat woul do..
Plz rate this solution.. thank you..
Apr 08, 2009 | Frigidaire ATF6000ES Front Load Washer
EFO, E10 error Message
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
Error messages EFO and E10
It is simple. The wrong soap or too much soap will caused EFO to flash. I overfilled the machine with soap by accident. It started flashing with EFO and I went nuts. What could be wrong with it now?! Too much soap or not the right kind of soap will cause this problem.
Plus, I found a sheet of paper that gives the codes.
This is better than when the strainer plug gets filled up and you have to take the machine apart to clean the little strainer.
Apr 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Frigidaire GLTF2940ES Front Load Washer Logo
325 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
