Toshiba 55H70 55 in. Rear Projection Television
Problem for Toshiba 55H70 55 in. Rear Projection Television
Having promblems getting the red to line up right.
By titmouse_72 on Sep 27, 2009
having promblems getting the red to line up right. it is giving a double picture on the bottom of the screen. not sure if this is the right year for our tv,but the picture you have looks like the one we have.
Solution #1
posted on Sep 27, 2009
Not Rated)
asnowman
Rank: Guru  Televisions & Videos  Expert
Rating: 95%, 602 votes
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 55H70 55 in. Rear
Questions and Unsolved Problems for Toshiba 55H70 55 in. Rear
Do you recommend Toshiba 55H70 55 in. Rear Projection Television?
Answer
Answer
we are unable to see the bottom print on the basketball games. It is cut off, is there anything we... (More)
Answer
power button turns on the tv, but the screen is black and there is no sound.
Answer
It won't turn on. The red light blinks and a click in the rear but the light does not stay on and no... (More)
Answer
where can get a frount screen for a tashiba 43vj33q my screen is broken i just need to find a screen... (More)
Answer
I have a Toshiba rear projection 55" cineman series HD. We had a power failure and when the... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , GA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
