Question about McCulloch Garden
Need a new clutch - McCulloch Garden
  • 8,404 Answers
Best place to get a clutch is a rental place that handles your brand.
Posted on Sep 27, 2009
Needs a new clutch
are you absolutely sure that it needs a new clutch
many a clutch has been replaced when the fault is the clutch master cylinder (if hydraulic) or clutch cable
Have it inspected by an accredited clutch and brake specialist shop and get a quote
Dec 10, 2015 | Skoda Fabia Cars & Trucks
When I let clutch out when cars in gear the car wont pull away if I turn engine off let it sit fr an hr then drive it its fine fr a while.
For awhile? How long? And then it slips again? I think you need a new clutch, your clutch disc must be worn. A new clutch kit includes a new clutch disc or plate, a new or rebuilt clutch pressure plate, and a new release bearing. Costs about $150-200,for the kit, but you also need the flywheel surface smoothed at a machine shop or garage, then the labor cost of removing the transmission or transaxle to replace the clutch- it all adds up to an expensive job.
Apr 09, 2015 | Cars & Trucks
Truck wont go when I release the clutch.
You need a new clutch. The clutch disc has worn out, now it's slipping on the flywheel. Clutch kit: new pressure plate, new clutch disc, new clutch release bearing, and new crankshaft pilot bushing- about $150-200, somewhere in that range..
Dec 24, 2013 | 1989 Ford Ranger
Clutch wont engage after new install
Maybe the clutch master cylinder is not building hydraulic pressure? The internal seals in it may not be holding. Watch the slave cylinder push the clutch lever while someone presses the clutch pedal. If travel is not enough and was bled properly, you may need a new master cylinder.
Jul 07, 2013 | 1991 Chevrolet S-10
No clutch
You need a New clutch. I assume it is to the floor and it still moves? You can try adjusting the clutch but in most cases you'll need a new clutch
Feb 28, 2013 | 1989 GMC Sierra
Clutch will allow me to turn the car on but I am unable the shift gears.
hi,
clutch slave hopefully. check clutch slave fluid, its next to the brake fluid reservoir. it takes brake fluid try bleeding the clutch slave. if it wont bleed then you will need a new clutch slave. If you get the new clutch slave and it still wont actuate correctly then its time for a new clutch. you may be able to shim the clutch slave pin with a small socket untill you get a new clutch but thats not recommended.
jm
Apr 08, 2011 | 1992 Honda Accord
I have a 84 Honda xr250. When I depress the clutch lever the transmission doesn't disengage and I am not able to change gears. The last time I rode it I had to adjust the clutch cable all the way to the...
yes sounds like you need a new clutch to me . you will just need clutch will need fibers, clutch plates, and springs and that should do it (pay attention to the pattern when you take them out, rightit down if you have to)
Mar 28, 2011 | Honda CR 250 R Motorcycles
I need the friction plates maximum wear specs
If the clutch is slipping you need to buy a new clutch pack,which will include clutch friction plates and thrust washers.As for specs if slipping and free play on handle is correct .Clutch is shot.I dont know the specs off hand.But if you are asking this question I would think you need new clutch.
Mar 06, 2011 | Honda VT 750 C2 Shadow Motorcycles
Garden Logo
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
