Question about Belling XOU492 Electric Double Oven
The main oven door will not shut tightly, how do you adjust it?
  • 142 Answers
If its a pull down door the hinges are prob worn and need replacing.
Posted on Sep 28, 2009
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: main oven door
This comment applies to most electric ovens that have drop down doors with hinges at the bottom.
The hinges are not adjustable, and in every case the problem is caused by one or both hinge springs being weak.
The only solution, is to replace both oven door hinges together.
Posted on Jan 10, 2009
barkencoa
  • 3463 Answers
SOURCE: Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
skrbin
  • 121 Answers
SOURCE: Need to adjust Oven door to shut tight
adjust on screws on door hinge
Posted on Feb 17, 2009
barkencoa
  • 3463 Answers
SOURCE: oven door won't stay tightly shut
Oven door hinges are not adjustable, assuming you have fitted the door back correctly, and it is still not closing properly, then the only solution is to replace the door hinges.
Posted on Jan 20, 2010
Oven door kleenmaid wont shut tight enough
Some are made where you just pull up on it and some you actually have to remove the bolts and stuff
Jul 29, 2012 | Ovens
Door will not shut tight. Can it be adjusted?
No adjustment is possible, normally the only solution is to replace both oven door hinges
Dec 26, 2010 | Whirlpool RBS305PDS Electric Single Oven
We just purchased a home that was built in 2003. It has a stainless steel double oven. The doors don't close tight. Is there a way to adjust them so they do? Thanks
I have the same problem on my AOCS3040 oven....door will not shut tightly so it loses heat and is about 25 degrees off plus the escaped heat makes the control panel get very hot during cooking.
Oct 21, 2010 | Amana AOCS3040 Electric Single Oven
Oven door won't stay tightly shut
Jan 20, 2010 | Whirlpool RBS275PD Electric Single Oven
Oven door not shut tightly. how do i adjust it ?
if the door does not have a door catch, then you will have to replace the oven door hinges.
.If it does have a door catch, then you will have to replace the door catch.
Please rate my solutionb
Thanks.
Oct 05, 2009 | Frigidaire Ovens
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
Thanks.
Jan 05, 2009 | Dacor ECS130 Epicure Electric Single Oven
Belling XOU492 Electric Double Oven Logo
668 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
