Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
WHIRLPOOL_LSR7133KQ0 wont start at all
Everything is is order and connected but simply wont start when the knob is pulled
  • 61 Answers
Make sure you have power at the plug
Posted on Sep 28, 2009
I accidentally twisted off the latch pin knob. Ordered a replacement, but how do I install it?
If you can get at it from the other side, it will be difficult. Is it screw in, or push in?
If it is screw in, you can drill a small hole in the centre of it and use a screw extractor which is a cone shaped hardened screw that screws in anticlockwise, so as soon as it grips it undoes the bolt.
If it is pull or push fit, you would have to strip down everything around it and get to it from the other side.
Jan 05, 2016 | Proform XP CrossWalk 580 Treadmill
Whirlpool Dryer LEO8857HQ. Selector switch. I'm not in front of the dryer now it's 1800 miles away in my sister's garage and she doesn't use a computer. The selector control knob came off in her hand and...
a piece of plastic from the original knob may still be on the shaft, thus preventing the new knob the ability to lock in place. Hope this helped Tim
Jan 14, 2011 | Whirlpool Dryers
Removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Jun 08, 2010 | Kenmore 24032\24036 Top Load Washer
How to install 3949238 in kenmore model 110.26912691. I have unscrewed the control panel, but the brass hinge wont come out
First, see the Sears parts site for your washer;
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
In order to replace the "dial" you have to release the console by snapping off the two end caps, unscrew the two phillips head screws, and pull and lift the console.
It should lean back and balance on the hinges.
To release the dials from the timer, you may have to hold the metal shaft on the back of the timer with a thin needle nose pliers while you un-screw the knob.
With the knob off, the dial simply pulls off.
May 28, 2010 | Kenmore 22642 Top Load Washer
My whirlpool top load washer will not start when I pull the knob. It makes a humming noise.
Motor sounds like its not starting up strong
May need a motor....
Jun 02, 2009 | Washing Machines
Whirlpool LSR7133kQ0 agitates, rinses and drains will not spin
you need to replace the spin tube which is located above the transmission you have to remove the tranny and the inner tub to even get to this part.if you need any help getting thru this let me know
bill
Jan 08, 2009 | Washing Machines
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
