Question about Technics SL-1200M3D Turntable
Turntable technics sl-bd27
There is no sound coming out from the right speaker and it is sure that is the turntable
  • 1 more comment
  • Anonymous Apr 17, 2009
    player is playing fine, and then the sound goes out in the right speaker.  If I tap the turntable with my finger lightly, it comes back on for a little while, but may go out again randomly at any time.
  • Anonymous Mar 15, 2014
    need wiring diagram
  • Anonymous Mar 16, 2014
    can i get a turntable compatible with my dv280 system
    Problem Solver:
  • 7 Answers
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
Posted on Dec 18, 2007
Poor sound quality from a technics SL-D210
Generally either a faulty connection to a lead or cartridge. Or a faulty Cartridge. If you switch the left and right channels of the phono leads the missing sound should move to the left and the right come to life. If it does not then there's a fault in the magnetic cartridge pre-amp in your amp.
Mar 29, 2013 | Technics Audio Players & Recorders
I have 2 technic sl1200s and the right table has noise coming out of the speaker when i moved the tonearm. when music plays, it sounds like the treble and volume of the right speaker is weaker help...
If your left technics sounds good, maybe the problem is the cartridge. Try to interchange the cartridges, right table cartridge by the left one, and listen. If now the bad sound comes from the left table, it´s time to get a new cartridge or stylus. If the problem continues there is something else to look for. Hope this will help. Flavio/Brazil.
Sep 17, 2010 | Technics SL-1210 Turntable
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
Technics 1200, no sound out right speaker
And it will be. I can almost steak my life on it. Easy to replace. Most djs had to already. Most off us went to Radio Shack and bought the 6 foot gold RCA's and cut them in half for both decks. Its not that hard to do. Any problems message me.
Oct 29, 2009 | Technics SL-1200MK2 Turntable
I PURCHASED A LIKE NEW TECHNICS SL BD27 TURNTABLE. I HOOKED THE RCA AUDIO JACKS TO THE AUDIO INPUT ON MY SONY TV AND GET VERY LOW SOUND LEVEL WHEN TV VOLUME CONTROL IS AT MAX. REPLACING CARTRIDGE AND...
Yes you need a pre amp
It would also be the same if you connected it to a computer to record an LP to CD. Mine is a little different and has one already built in that I can switch in and out of line.
Try spend a little more if you can as many pre amps can introduce noise.
You may also want to check that the turntable is properly grounded to prevent noise too
Oct 02, 2009 | Technics SL-BD22 Turntable
Technics turntable model SL-bd27. center spindle rubbing noise.
hi, try to open or remove the platter on the deck, maybee there some small thing inside..
Apr 09, 2009 | Technics SL-1200M3D Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Where is the ground wire connected to on the Technics SL-BD27?
You will more than likely need to wire it up from the inside of the unit, unfortunately. Parts for this model are discontinued. You can also try an iPod cable. As the size is a 1/8" plug - same as an iPod cable, then just cut the other end, and ground to your receiver.
- TERMiNAL OPTiC
TWEAK AV REPAIR
Jan 09, 2008 | Technics SL-1200M3D Turntable
Technics SL-1200M3D Turntable Logo
845 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
