Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag washer LAT9356AAE won't spin out and has a burning smell
  • Greg Trobaugh
    Greg Trobaugh Feb 23, 2012
    Misinformation!
    Solution provided by oldguy5 is totally worthless since the manual is not for the LAT8504AAE which is a top loader!
    Don't post answers if you're clueless!
    President:
  • 1,937 Answers
Following is a PDF service manual for the Maytag Neptune washer from the Whirlpool / Kenmore / Maytag site.
It has an excellent troubleshooting section but may take a few minutes to load.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
Posted on Sep 27, 2009
Totally worthless since the manual is worthless for the LAT8504AAE which is a top loader!
Posted on Feb 23, 2012
2 Suggested Answers
FAV6800AWDIY
  • 526 Answers
SOURCE: maytag washer agitates bit won't spin
If no one responds to your request try this site and others. This was a quick search on your model… I’m an owner and only have knowledge of the FAV6800AW…… Good luck .... Rich
Posted on Oct 31, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Washer won't wash or spin has a burning smell then shut off.
A burning smell confirms the fact that there is a serious fault . All what is required once the smell is detected is to remove the panel and check for the part that is heating up. You can first check the main motor, check for leaked capacitors, check if the smell comes from the control panel or the valves, pump.
since the smell is present the part will be heated up and so is hard to confirm.
Your observation to confirm is most important before we go to the next step as the damaged part thus detected must be replaced.
Oct 07, 2011 | Maytag PAV2300 Top Load Washer
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
My washer wont spin and it smells like it is burning it is only 3 yrs old
The burning you smell is probably the belt slipping. There is a belt which is attached to pulleys. The belt engages to spin the basin in the washer. When this belt slips the burning smell happens because the pulleys are spinning and the belt isn't. You will probably need to adjust the tension on the pulleys or get a new belt. This can happen from constantly overloading the washer or trying to get the washer to wash and extra large load while the water level is set at a smaller load.
Aug 07, 2010 | Maytag Washing Machines
Maytag washer agitates bit won't spin
Oct 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer not spining burn smell
belt burrt out advise new belt or new machine
Jul 12, 2009 | Maytag LAT3600A Top Load Washer
Maytag LAT9356AAE drive pulley stuck during spin cycle
I had the same problem called a repair guy who told me the transmission is ceased up and the main bearing and seal is shot. Told me that Maytag uses defective parts in their machines and recommended direct-drive washer. Repair would cost more than to buy new. Sorry!
Nov 09, 2007 | Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
837 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
