Question about Singer 14SH654
Singer serger machine is jammed and won't cycle
My singer serger machine is jammed and won't cycle in a full circle as it should. I don't know if the timing needs set? Not sure how to do that?
Michaelle
  • 65 Answers
SOURCE: How do you thread the Singer QuantumLock 5 Differential Feed?
www.singerco.com/pdf/14SH654_threading.pdf
Its a different model, but most sergers thread the same way.
Posted on Mar 30, 2009
Mimito7
  • 128 Answers
SOURCE: needle for a singer tiny serger
Hi, ALthough it is called a "Tiny Serger", it will still take regular singer serger needles.
Posted on Apr 24, 2009
JeremySew
  • 65 Answers
SOURCE: need instruction manual
http://www.sewingpartsdirect.com/singer-sewing-machine-instruction-manual.aspx
Posted on May 07, 2009
Mimito7
  • 128 Answers
SOURCE: Missing Manual for Singer 14U134 Serger
try this;;;
www.2instructions.com
Posted on May 29, 2009
SOURCE: Singer Tiny Serger: Motor runs but machine
pull the 4 bottom rubber feet out and remove screws hidden in holes. Lift main body of serger up. you will see the gears. Probably drive gear on motor shaft got hot and slid on motor shaft.
Posted on Dec 12, 2009
Tip
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
SingerSewingCompany
presser feet tutorials,
SingerSewingCompany
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
http://www.sewingpartsonline.com/
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
babylock,
http://www.babylock.com/support/faq
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
How to thread a serger Singer 241
check these sites
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 241) & click search
if they don't have what you need contact singer customer service
or
sew4less.com
premiersewing.com
sewusa.com
mastersewusa.com
Apr 07, 2012 | Singer Tiny Serger TS380
I am on the second letter of an embroidery pattern and the needles keep breaking. I have tightened everything as much as possible. I have never had this problem before. I am using the correct needles. Any...
I have a babylock serger & I use SCHMETZ UNIVERSAL NEEDLES on the serger & I don't have any problem with the serger
you should also check the tension to make sure it correct for fabric & needles
also make sure the needle is not in backward--flat side goes to the back of the machine.
if you need a manual contact babylock customer service
Mar 26, 2012 | Singer Quantum XL-1000 Computerized Sewing...
Singer Overlocker/Sergers require particular threading order. If that does not help you may as I did have to take it to an Authorised repairer. It has to be a Singer Authorised as they have done training...
Sergers thread upper looper first, lower looper second, right needle third and left needle last in that order. If your thread breaks, CUT ALL THREADS and start from scratch or you will not get a good stitch or your machine may jam. It's probably just a "user error."
Good luck.
Jun 17, 2010 | Singer 14SH654
Needle for a singer tiny serger
Apr 23, 2009 | Singer Tiny Serger TS380
I am looking for the correct settings for my Singer serger.
The easy way to reset an overlocker (serger) is to ensure the tension units are all clean and lint free, then use a different colour for each looper and needle/s.
Sew a sample, check front and back, make a small adjustment as required, another test, and so on until an even result is achieved.
If the tension dials pop off easily you can then put them back on so they are all on the same setting (Janome uses 3 as their base setting).
If the knob or dial is fixed, just write down the new settings and keep with machine........the lint is important, as it can jam in the tension dials and hold them open, thus reducing tension, so make sure they are CLEAN !!
See-saw a length of clean fabric moistened with methylated (denatured or surgical) spirit between the discs to be certain.
May 04, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer 14SH654 Logo
123 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
