Question about Cameras
Adjust exposure on s5700
My wife has a fuji s5700 but it always takes pictures which appear a bit light. we cannot find the manual and i cannot find anything in the menus to help in adjusting the exposure.
4 Suggested Answers
SOURCE: Fuji S5700 Replacement LCD
I just purchased a replacement LCD screen off of Ebay from a seller called D & H Camera in Chicago, IL. The cost was $49.99 (Buy it now) with a $15 shipping fee. It came very quickly and I am going to attempt to install it myself although the seller offered to do it free of charge if you would rather send it to him. The local camera shop from where I purchased the camera said it would cost as much as the camera did to replace it so this is a good deal in my opinion. Good luck.
Dean K.
Hershey, PA
Posted on Dec 27, 2008
lock123
  • 6831 Answers
SOURCE: my FUJI FINEPIX S5700 Digital Camera keeps saying
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
  • 4 Answers
SOURCE: Fuji s5700 my flash is not popping up on auto
Don't blame the Fuji Designers for this fault - it was the Fuji Bean Counters that are at fault - the flash design is for TWO springs, the plastic casting has the holes for a second spring on the other side - which wasn't fitted so 100% overloaded the single spring mount.
Anyway if you are brave and handy you CAN fix this.
First remove the back of the camera - 3 screws in battery bay, 1 in the side above the memory card door, The two rear most on the bottom, two in the USB/video door, and the rear most on the left hand carry strap bracket.
Carefully prise the back rearward about 5 to 8 mm.
Now take a look at the two screw holes under the flash (when popped - or flopped out now that is broken) now go and bend a screwdriver of the type you used for the previous screws - you will need a 90 degree bend very close to the tip to fit in this gap and be able to turn the screws a few degrees at at time.
A little at a time lock the screwdriver into the screws and undo until the flash cover comes off.
You can then slide the shaft out of the flash to release the spring which will have the end that should fit into the broken bracket now sitting proud..
Make a suitable bracket like the one in the photo attached to slide over the broken plastic bracket.
make sure it fits really well the epoxy into position.
Getting the spring back in is a fiddly job - I found the best way was to fit the end of the spring into the new bracket, slide the shaft just into the spring - the lever the other end of the spring down into the back of the flash body and then slide the shaft all the way into place.
I did have to file down the little plastic "blade" inside the lid which presumably is designed to assist the the (now broken) bracket from breaking....
reverse the dis-assembly and now you should have a working flash bb61266_2.jpgbb61266_1.jpg
Posted on Dec 05, 2010
Fuji finepix s5700 digital camera
Hey Sharon.Dose the error appear when you directly connect the USB cable to the pc and try to download the photos on the camera?
Nov 21, 2011 | Fuji FinePix S5700 Digital Camera
Dont no how to download my photos from my fuji finepixs s5700 to my pc
you can do it either by installing the finepix viewer and connecting the Cam to PC via the USB. the transfer rate is very low. For better transfer rates you can use a card reader
Apr 26, 2009 | Fuji FinePix S5700 Digital Camera
Over exposure photos
Try change the exposure of the camera: start the camera, set the dial to 'I' (automatic iso), then press the 'up' menu near the display until 'exposure' settings appear. move the slider to the left/right, according to your preference.
I reccomend using the automatic iso for taking pictures, it automatically adjust exposure.
Apr 25, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
We have a new s5700 but fin annoying blue vertical lines on the p
ur CCD is getting weak kindly run for warranty claim or if u dont have u still have hope email fuji support if u are even out of warranty they will repair it free of charge just request them it is manufacturing fault in some types of CCD imagers pls dont worry they will solve it
see this link it does not have ur model but i am sure they will replace it free of charge u just email them with ur problem see the email at www.fujifilm.com
http://www.imaging-resource.com/badccds.html
pls rate me FIXYA if u like
Jan 30, 2009 | Fuji FinePix S5700 Digital Camera
Changing Shutter Speeds
The +/- button is located on the bottom right corner on the back of the cam. If you do not find it on your cam, probably "you are not using a Genuine Fuji S5700".
Aug 07, 2008 | Fuji FinePix S5700 Digital Camera
Pictures are "grainy"
This may work, remove the batteries to try to "reset" the camera.
Jul 03, 2008 | Fuji FinePix S5700 Digital Camera
Can't find my camera Fine Pix S5700
You don't need the software. Connect the cam to the PC, press START, double click "My Computer", look for the Fuji Cam icon, double click on it, drill down until you see your pics, and you can drag and drop them into any folder you like on your computer. You'd have to transfer them to the net some other way.
Jun 22, 2008 | Fuji FinePix S5700 Digital Camera
Memory Card problems
It may sound stupid and obvious but try just taking the memory card out, give it a bit of a blow/wipe and putting it back in again, worked for me when my s5700 said it had a full card or that there was some other problem with the card
Jan 23, 2008 | Fuji FinePix S5700 Digital Camera
Why do my pictures look too dark?
You may need to use the flash. Make sure the setting is not flash off. If you're using the flash, make sure your subject is within the range of 14 feet for wide angle shots or 11 feet for telephoto shots. Use Image Expert to adjust the picture's brightness and contrast. Try adjusting the camera's exposure or sensitivity settings (use the Manual user mode). If you're taking pictures in the Manual user mode, look for the EV! warning that appears on your LCD screen when you are taking pictures out of the ideal exposure range. If you have trouble setting both the aperture and shutter speed manually, try adjusting the aperture and letting the camera choose the shutter speed with Aperture Priority mode. If you're using the macro mode to take a close-up photo, be sure to provide adequate lighting for your subject. If you're taking a picture at night and you want to light up the background as well as your subject, use the camera's slow synchronized flash mode. If you need more light, attach an optional external flash to the camera's hot shoe.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
