Question about Kwikset Professional Door Lock installation Kit
Cannot match up the screw holes. everytime we think we have it the screws just spin HELP!
  • maltedad Sep 27, 2009
    Thanks milleraba. We have only been trying this for the past TWO hours.
  • 8,404 Answers
What I do in this situation is put my tongue out the left side of my mouth about 1/2 inch.
My friend, you must look closely at the screw and the place you are screwing it into. They are not easy to line up. I have faith you can do this ... but it takes patience and a lilttle practice.
go try again.
a
Posted on Sep 27, 2009
Testimonial: "As it turns out the screws with the new set were to short. I wish I had read your remarks before we finally measured old ones to the new. "
  • A Miller Sep 27, 2009
    My comments were for the most likely.
    If not the obvious, it is probably one of three possible additional conditions.
    a) The screws are too short or
    b) too little or
    c) the holes into which you want to put the screws are stripped already
    I'm sorry you didnt find any help in my comment.
I have a Polaris 280 and one of the two screws that holds one of the wheels on is stripped.
You are referring to the wheel axle. The axle is held together to the vac sweeps base, with two bolts and nuts. What you can do, is remove the stripped one, going thru to get another new STAINLESS STEEL, bolt with a matching nut, and tighten it from the bottom. You will need to get access to the bottom, by removing bottom cover - two fasteners hold that.
Don't be intimidated, it doesn't matter what you use - a bolt or ???, you just want to secure the axle to the base. I would recommend a bolt and nut.
I added a link below, to show a diagram of the unit all taken apart.
Area of significance: Parts 13-16 The nuts, are recessed in a small Divet in the bottom of the middle bass.
Vac Sweep 280
Apr 14, 2015 | Pool & Spa
How do we get the counter screws to catch
If you are sure you have the correct screw, you can try adding a wooden match stick in the hole. The soft wood will provide grip for the screw and collapse in the hole as it is screwed in.
May 26, 2014 | Furniture
How to fit the splashback
Hi Do you mean the screws don't match up with the holes ? I find this all the time I drill new holes to make it fit correctly. One thing you should know is stainless is very hard to drill so go to the hardware store and get a bit for stainless and also get it just a little smaller then the screws, if you bring the screws with you they will help you get the correct bit , rate this call thanks Frank
Dec 13, 2011 | Baumatic B187 Stainless Steel Electric...
The screws that hold our doorknob don't hold the knob anymore.They have loose threads and the screws are already too short that they don't hold the knob anymore. Everytime we turn the knob and pull it to...
Get a tap and re-tap the threads to the next screw size up. Then get matching setscrews. You could put a bit of Loctite on the new screws to keep them secure. Use a FINE thread tap so you get more threads in the knob.
Another solution is to clean and fill old screw hole with metal filled epoxy. Let is dry and re-drill and re-tap to original thread. Devcon makes a filled epoxy as well as JB Weld.
Mar 18, 2011 | Garden
Where is the number one plug wire go at on the distruber cap
Sometimes the cap is marked #1. sometimes not, inoder to find # 1 you will need to pull the number one sparkplug and spin engine until compression pops out of plug hole, you will be tapping the key not holding it because you will pass it,then use a light or long thin screw driver and then continue to spin engine but this time quick taps until the piston reaches the top of the cylinder, note remove the coil wire so engine does not start,you can also spin the crank when your close with a socket, spin engine until the screw driver is up when you feel if start down go back a touch thats top dead center, remove the distributor cap and look at where the rotor is pointing, then match with the cap terminal thats # 1. hope this helps.
Sep 06, 2010 | Ford F-250 Cars & Trucks
I have a ct227 and I need a door handle. The elbow on the left the screw hole is stripped.
Hello. If the screw hole is stripped, you can repair that by using some one minute epoxy and a wooden match stick to make the hole smaller. Just work quickly in this sequence:
1. force some epoxy into the hole.
2. put epoxy on the match stick and push it into the hole.
3. Break off the match stick so it is not too long
4. Align everything and drive the screw in to the repaired hole.
5. let it set up for a few minutes before using it. J.
Jun 14, 2010 | Ovens
After replacing 3 --> 4 prong cord, why don't the screw holes
The screw holes should match up. Loosen the 1 screw on the cord clamp that keeps it tight. Maneuver the back plate until it lines up then re-tightened the screw for the cord clamp.
Sep 20, 2009 | GE Dryers
Hey sorry about the messages but
ok their,those screws you see did screw into a plastic housing[lid switch] that now has cracked and the screws are bairly hanging on to the switch.now here goes...unplug you washer,and reach your hand in there,break or pull that switch up where you can work on it.you then can tape the lever in the run position[down]now thats if its not broken[the housing]now if you have done this your washer will not !!!!!!!!!!!! stop in spin cycle when you lift the lid.soooooooo if you or a child or wife put your arm in there while it was spinning[danger][will robinson] their have be cases of persons getting their arms torn off.sooooooooo,get a new switch and you dont have to worry.if you have small children they are curious and will play with the washer when you are not looking.i did at my home.anyway im there if need more help,email........God bless ,tom
Jan 09, 2009 | Kenmore 46462 Front Load Washer
Tiny holes in clothes
We have the same problem. Look at the agitators inside the washer. We found strings and material there. Not sure what or if there is a fix bout I just saw the problem 2 days ago.
Aug 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Ativa dx200d Shedder Plastic gear
Drill 3 or 4 holes along the path of where each gear tooth is missing. The holes should be sized to about 75% of the width of the tooth at its base. Drive appropriate sized screws into the holes. Clip off the tops of the screws to match the original tooth height. File the sides of the screws at an angle to match the original tooth sides. You are essentially replacing the missing gear tooth with three or four screws filed to match the tooth profile.
Jun 07, 2008 | Office Equipment & Supplies
Kwikset Professional Door Lock installation Kit Logo
241 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
