Question about Panasonic AG-1330 VHS VCR
Tape seems to be stuck to itself, I can't free it up
I have a video that was made in 1988 of my great uncle, and it is very important to me, he was telling history of the indians being shipped to a reservation, but the tape is stuck, I have a recorder to put it on a dvd, but it won't budge. I try to move it with my fingers, roll the tape, it isn't rewound all the way, but it won't move, would some sort of spray, wd 40 or such do any good, or would it finish it off?
Please help if you can
  • Panasonic Master
  • 5,151 Answers
I think you are refering to the tape itself in the VHS cassette and it not being stuck inside the Video itself!
So if you are... don't use the spray... video cassettes have a brake system inside them. It sometimes breaks. If you turn the cassette upside down so you can see the white reels, inbetween them near the bottom (where the side label goes) you will see a small hole. If you put a pen inside it should release the reels so you can turn them with your finger. If they don't turn it may be broken. In which case... Get hold of a blank tape, the same length as yours. Carefully remove the screws (5) on the bottom. See how it's put together. Once you understand how the tape moves etc. Take out the reels with the tape, then dismantle your video and put the reels with the old tape into the new holder. It should work as good as new.
PS try not to touch with fingers the tape.
Posted on Oct 05, 2009
Remove stuck cassette tape
To remove the tape you will need to pull the whole unit out of the dash and disassemble it.
Jun 11, 2017 | Kenwood Car Audio & Video
Stuck head unit-- need help understanding the mechanics of a tape deck.
The solution to the problem comes from recognizing the type of transport the unit uses. This can be discovered by looking at the working side or by a person who has some experience working on these. Chances are there is a stuck flywheel assist mechanism and just because the belts are no broken or not turned to goo, that does not mean they are good. Also does the capstan motor turn? If it does not, there is no way the mechanism can right itself and that might mean a new capstan motor. Dual cassette decks were built for profit not for a long lasting unit- that is why the thrift shops should be full of them and why most of them will not work.
Aug 11, 2012 | Sony Audio Players & Recorders
I have a sony TC-660 reel to reel player, it had been in great condition, and i love using it. All of a sudden however, the reels will ONLY move in one direction (clockwise for the left, and counter...
In order to maintain tape control and tension the reels always pull lightly in opposite directions during PLAY mode. The capstan moves the tape in the desired direction at a precise speed. If the capstan doesn't engage the tape BETWEEN itself and the pinch roller you'll get the reels battling over control of the tape. Check the tape routing.
May 25, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
Tape stuck in VCR
With care, it is possible to retrieve the tape. VCR housings are held on only with a half-dozen screws and once those are removed, you will be able to see the transport. If the tape itself was defective (it only takes a stretch of tape with finger oils on it) then you will see it wrapped around several things with the worst of it around the drum itself.
The transport, if its control electronics has died, can be operated by hand once you have the tape free and laying loose so that you can manually eject the tape.
If you have made it that far, you will have a cassette with a long loop of tape dangling out.
On the bottom of the cassette is a hole a little larger than a pencil in diameter and you have to use something like a pencil stuck in the hole to release the brake. Once released, you can turn the takeup reel from underneath and wind the tape back into the cassette.
Unless the VCR is totally dead, I would take another cassette, one that isn't important to you, and see if that one will load while you watch the mechanism. If it loads and can be ejected afterward, then the first cassette was at fault in the jam.
DON'T touch the surface of the video head unless you clean it throughly with a soft cloth and some window cleaner afterward.
Jan 05, 2009 | RCA DRC8300N DVD Recorder/VCR
R 0:00 -- can't play back tape
try to clean the video head...i advise to use a blank tape and fastforward it until the time code counter display...you should on it the menu of the camera..
Aug 05, 2007 | Panasonic PV-GS500 Camcorder
Tape stuck and tv turns off
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Jun 01, 2007 | Sylvania 6313CB 13 in. TV/VCR Combo
Panasonic AG-1330 VHS VCR Logo
159 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
