Question about Samsung L200 Digital Camera
File corruption when i go to look at my pictures it freezes and eventually says file corrupted
My Kingston DataTraveler G3 8GB USB 2.0 USB Flash Drive (White/Yellow)'s data all got corrupted, and i a cannot do anything [copying, pasting, renaming, moving, etc.] with the corrupted files/data
Get data back is a file recovery program for flash drives, it may work for this, but if the files are corrupt you would then be recovering corrupt files.
Apr 20, 2013 | Computers & Internet
My toshiba satellite series keeps freezing up when idle and I have to do a force shut done, any suggestions?
Best suggestion is to back up your files and reinstall the OS.
If it freezes while idle, some necessary data is most likely corrupted.
Force shut downs often cause system files to corrupt.
Oct 18, 2012 | Toshiba Satellite L305-S5908 Notebook
Freezing frequently ?
The cause of the freezing, or locking up, of your computer, is due to some either corrupted or missing files. And more specifically, missing or corrupted registry files. These are the files which tell everything on your how it is suppose to work. Basically, they are configuration files. And if these files get corrupted, or messed up, it can wreck havoc.
Sometimes the registry files end up missing. This can happen when you uninstall software from your computer. The software being uninstalled may remove registry files also associated with another program. There should be a message asking you whether or not you want to delete the files as they are associated with another program. Your best bet is to say NO to this and leave the files. If the files end up missing, then the program which needs them will stall, hang, or freeze the next time it tries to run. But there is a simple way to fix this.
By just running registry scan software on your computer, you can find these problems and fix them right away. It will let you know which files are bad, and will fix them to its original state. And it is this simple step which will show you how to fix your computer freezing.
Dec 13, 2010 | Dell Inspiron 560 PC Desktop
Computer freezes
The cause of the freezing, or locking up, of your computer, is due tosome either corrupted or missing files. And more specifically, missing orcorrupted registry files. These are the files which tell everything on your howit is suppose to work. Basically, they are configuration files. And if thesefiles get corrupted, or messed up, it can wreck havoc.
Jan 11, 2010 | ASUS K8N-E Deluxe Motherboard
Computer freezes way too often
if you are still having file corruption problems after a full restore, i am willing to bed you have a bad hard drive. it's possible you can repair the corrupted sectors with chkdisk, but you will mostly likely have to have a new hard drive put in.
hope this helps
Jan 16, 2009 | Gateway M-6866 15.4" Widescreen Laptop...
Ps3 freezes everytime i load a game
It could be a corrupted save file.  Something similar happened to me.  If your game freezes too much while loading a file it can become permanently corrupted.  You should back up your save data on a flash drive or other device.  As for your problem, i'm not sure the cause.  Perhaps you should try other games
Jan 08, 2009 | Sony Playstation 3 (PS3) Console
Deleting files from memory card
If the memory is corrupted then the corrupted data will show as blue squares. Delete them. Make sure that there is no game inserted when you do this, as the game may be causing the freeze.
Nov 14, 2008 | Sony PlayStation 2 (PS2) Console
The pictures from sd card freeze when I run the slideshow on my digital picture frame. Does anyone have any suggestions as to what the problem might be.
Does it stop on one particular picture? If so, I would say that you have a corrupt picture file on your SD card.
Nov 09, 2008 | Computers & Internet
Picture file corrupted
no your file has been corrupted.. sorry.
Jul 24, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Memory corruption
mine has the same problem its stuck at the repaired! content cleared! thing
Dec 15, 2007 | Philips SA5125/37 MP3 Player
Samsung L200 Digital Camera Logo
106 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
