Question about Mitsubishi VS-70707 70" Rear Projection Television
I purchased from a couple the Mitsubishi Projection TV 70" Model: VS- 70707 Serial (if this helps): 108071 and I got it into the house (handled with extreme care) and plugged it in and tried to turn it on. Everytime I try to turn on the TV I press the power button and the TV does the sound that it's going to start up for about a second and then turns right back off. I tried the holding "MENU" and "INPUT" technique and it worked. I got the blinking timer code which was "20". After holding down both buttons for 5 seconds the timer green light blinked 2 times then paused and blinked another 2 times. I was trying to see what the problem is and if it can be fixed easily (which I doubt) or if I need a professional to come out. If I do need one coming out should I call Mitubishi Support Center? I bought the TV from some people and I don't have warranty (I don't mind spending money getting the TV fixed, it's a 72" inch which is nice and big!) I don't know what year it is. Here are links to 2 pictures of the TV so you know exactly what your dealing with. http://i62.photobucket.com/albums/h118/Roskeet69/DSC06120.jpg http://i62.photobucket.com/albums/h118/Roskeet69/DSC06121.jpg Please help me out as I want to get this TV working. Thanks a lot, Roscoe Hanner.
  • jasonespi Sep 27, 2009
    I purchased from a couple the Mitsubishi Projection TV 70" Model: VS- 70707 Serial (if this helps): 108071 and I got it into the house (handled with extreme care) and plugged it in and tried to turn it on. Everytime I try to turn on the TV I press the power button and the TV does the sound that it's going to start up for about a second and then turns right back off. I tried the holding "MENU" and "INPUT" technique and it worked. I got the blinking timer code which was "20". After holding down both buttons for 5 seconds the timer green light blinked 2 times then paused and blinked another 2 times. I was trying to see what the problem is and if it can be fixed easily (which I doubt) or if I need a professional to come out. If I do need one coming out should I call Mitubishi Support Center? I bought the TV from some people and I don't have warranty (I don't mind spending money getting the TV fixed, it's a 72" inch which is nice and big!) I don't know what year it is. Here are links to 2 pictures of the TV so you know exactly what your dealing with.http://i62.photobucket.com/albums/h118/R...http://i62.photobucket.com/albums/h118/R... Please help me out as I want to get this TV working. Thanks a lot, Roscoe Hanner.
    ERROR CODE "20" NOT "22"!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Mitsubishi Master
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Im trying to find a replacement screen for a Mitsubitshi VS-70707... is there anywhere I can find one or some sort of similar product that will work?
Find an active TV Repair shop. You may find a used screen in their salvage area. If they don't have one, they will know of another TV shop that may. Thanks for asking and show all hands of support!
Sep 06, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Our toddler pressed several buttons on our Mitsubishi VS-70707 rear projection tv, it powered off now we can't get it to power back on?
Very simple , you need to initialize you tv by pressing menu and input bottoms at the same time for 30 seconds until the picture coming up and select * intitialize* on the screen menu, and wait until is done and you done.
Dec 18, 2010 | Mitsubishi VS-70707 70" Rear Projection...
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
I turn on the TV and after about a second it turns back off
22 error is the code for short protect which could be the two STK392-110 Convergence ICs as thats the number one component to short out . It could also be leaking coolant check the boards for any sign of a sticky residulr that would indicate that the CRTs are leaaking coolant on the boards.
Apr 27, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Good day, crsomers1;
The 'giggling' may be a horizontal problem, also known as pie crusting. Try this first: unplug TV from wall, reset or reboot. Secondly: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
I hope this was helpful, good luck, big IRISH.
Jul 03, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Vs-70707 dark on power up
Aug 02, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi rp vs 70707
Do you know if this is what the problem is? If its color problems or convergence alignment then:1. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12596" TO ENTER THE CONV MISC. MENU THEN "8970" TO RESET.
Jul 28, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi VS-70707 70" Rear Projection Television Logo
185 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
