Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
How to fix automatic ice maker thats not getting
Had a leak in the tubing so we replaced the tubing and fitting going from main supply to fridge after that ice maker stoped getting water but all lines have water its just not getting into the ice maker
  • 4,070 Answers
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
Posted on Sep 27, 2009
Ice maker is leaking water.
hi John.
Troubleshooting an Ice Maker That Leaks
When troubleshooting ice maker there are a lot of different things to be aware of. Ice makers are very useful when working correctly, however if there are any problems, it's important to fix these as quickly as possible. One common problem with ice makers is that they can leak. A leaking ice maker can be a result of a number of different reasons.
You will need to put your detective's cap on in order to inspect and diagnose what is actually causing the problem with your ice maker.
Checking Your Refrigerator For the ice maker to work properly it needs to be perfectly level. If it isn't level, this can cause leakage.
Before leveling the freezer you should unplug it so that you can work on it safely. Check that the freezer is perfectly level by placing a spirit level on top of the freezer from side to side. The leveling feet can then be adjusted by twisting them to raise and lower them. Continue this until the freezer is aligned properly from left to right.
Then repeat the process by putting your spirit level from front to back to ensure the freezer is completely level.
Ice Maker Level The ice maker unit itself can also be leveled. This is inside the unit and can be repositioned if needed. Loosen the mounting screws and align the ice maker unit so that it is perfectly level. After leveling, ensure that the mounting screws are tightened to prevent the ice maker from moving.
Water Supply Line The water supply line could also be damaged or broken. This is the tube that is behind your freezer. It's a fairly strong tube and is susceptible to damage. Check that the pipe isn't pinched or kinked.
Fill Cup When water enters your freezer it will be put into the fill cup. This is a funnel that directs the water into the ice cube molds. If this isn't aligned correctly, it can cause problems with leaks.
If you see any ice forming on the fill cup, this could be because the valve is not working properly.
Inlet Switch Remove the inlet switch and inspect it for signs of corrosion or damage. If any of the terminals have corroded, you will need to replace them. Using a multimeter, you can check that the switch is working properly. Press the switch and check that it connects and reduces the resistance as it should.
Inlet Valve If you are testing the inlet valve, you must first disconnect the power so it's safe to work on your freezer. The inlet valve is located in the bottom of the freezer. Turn the water off at the source and then disconnect the supply line. Use a bucket to catch all of the water from inside the inlet valve.
Label the location of all the wires and disconnect them. You will also need to remove the inlet supply tubes. Using a multimeter, check the resistance of the coil. Also inspect the mechanical functioning of the inlet valve, as it can fail mechanically as well as electronically.
After following this troubleshooting guide for your ice maker that leaks will get you back in business. Now you can enjoy a cold beverage for your hard work!
Comments Troubleshooting an Ice Maker: Ice Tastes Bad
Shares
When troubleshooting ice makers there are a number of steps that you can take to find the cause of the problem and put it right. One common problem is when the ice doesn't taste right. If the ice tastes bad, then there can be a number of reasons for this.
When working out why the ice tastes bad there are several things that you will need to consider. The problem could also be caused by one or more of the factors that could make solving it slightly move complicated.
Washing the Ice Bin The ice bin is the container that stores the ice, if this becomes dirty or moldy it can make the ice taste nasty. Simply taking the ice bin out of the freezer and then washing it will solve the problem. Read the instruction manual to find out where the ice bin is located.
Unscrew or unclip the ice bin and then wash it in warm soapy water. Dry the ice bin and then reassemble it. Place it back into the fridge and then find out whether it has resolved the problem.
Old Food If there is any old food in your refrigerator, it should be removed. The ice could taste funny because of this food. Empty your refrigerator of any old food and wash all of the shelves so that the fridge is completely clean.
Once the old food has been removed and the fridge has been cleaned completely you should then test the ice maker to find out whether the problems still affect you.
Flushing the Supply Line The supply line carries water to the ice maker. Sometimes the water can become stale, which is why you might be able to cure the problem by flushing the water pipe out with fresh clean water.
Test the ice maker after flushing the supply line to ensure that the water is now clean that the ice doesn't taste bad.
Water Inlet Valve If the water inlet valve is damaged, then this could also be because of the water inlet valve. If the water inlet valve is damaged or broken, it can leave the water exposed to smells inside your fridge, which can make the ice taste bad.
The water inlet valve will need replacing if it is damaged or broken. By replacing this water inlet valve you will be able to correct the problem and enjoy better tasting ice.
Replacing the Water Filter There is a water filter inside of your fridges ice maker that is designed to remove particles and bad smells from the water. The water filter needs to be removed and replaced.
The water filter should be replaced with the same type and model suitable for your freezer. Use your freezers model to ensure that the correct filter is fitted.
Supply Line Filter If your fridge doesn't already have a supply line filter, then fitting one could greatly help to reduce problems with the ice tasting bad. These can be fitted to virtually any ice maker.
Now you should be in good shape thanks to this troubleshooting guide for an ice maker that was producing bad tasting ice. It's time to reward yourself with a cold beverage.
Dec 08, 2017 | Refrigerators
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Cu2026 not making much ice
Sometimes the water inlet gets clogged. This happens a lot if u are using well water. Take the water line loose from back of fridge. fold the tube to stop water from leaking on floor if it is a plastic tube. have a bucket handy and put line in bucket let the water flow. It should come hard and fast. If not go to water valve where it pirces the main water line. check the hole and make sure it is large enough to supply the water. I had to take a drill bit and make the hole a little larger. That fixed mine. If that is not the problem then I would replace water inlet valve on the fridge.
Mar 20, 2014 | Kitchen Appliances - Others
It leaks water from underneath
If the water is coming out from under the fridge and you have a water dispenser or automatic ice maker, then I would suggest that you pull the fridge out from the wall and check the water tubing going to the back of the fridge. The tubing is connected with a compression fitting (a special nut that compresses the tubing to the fridge. There may also be a few more pieces of tubing on/in the back of the fridge with these fittings. Place you fingers on each fitting to see if it is loose or wet. If you find a wet or loose fitting, take some pliers and tighten it (snug it up, but not too tight because you can damage the fitting. Dry up the water. Watch the fridge for a while to make sure the leak is stopped. If you can't get it stopped, or if it gets worse, you can cut off the water (there should be a valve under a cabinet next to the fridge, or under your sink). You can get a replacement fitting at Lowe's2_bing.gif and they can tell you how to install it if necessary. If you have water pooling under your fridge and it goes up to the wall, then you should check on the other side of the wall for water also. This happened to our fridge, but we did not see the water in front of the fridge because it ran to the back of the fridge and under the wall into our carpet on the other side. Wet carpet is how we discovered the problem.
May 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is coming out on the floor in front of the fridge, what might be wrong?
If the water is coming out from under the fridge and you have a water dispenser or automatic ice maker, then I you should pull the fridge out from the wall and check the water tubing going to the back of the fridge. The tubing is connected with a compression fitting (a special nut that compresses the tubing to the fridge. There may also be a few more pieces of tubing on/in the back of the fridge with these fittings. Place you fingers on each fitting to see if it is loose or wet. If you find a wet or loose fitting, take some pliers and tighten it (snug it up, but not too tight because you can damage the fitting. Dry up the water. Watch the fridge for a while to make sure the leak is stopped. If you can't get it stopped, or if it gets worse, you can cut off the water (there should be a valve under a cabinet next to the fridge, or under your sink). You can get a replacement fitting at Lowe's and they can tell you how to install it if necessary. If you have water pooling under your fridge and it goes up to the wall, then you should check on the other side of the wall for water also. This happened to our fridge, but we did not see the water in front of the fridge because it ran to the back of the fridge and under the wall into our carpet on the other side. Wet carpet is how we discovered the problem.
May 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker has stopped making ice
Check the ice maker to see if there are ice cubes in the ice maker. If so, there is a problem with the ice maker heater and / or motor. You may be able to rebuild the ice maker by replacing defective parts, but it might be easier to replace it as a whole unit instead. If there is no ice present, it is likely a problem with the ice maker water lines / solenoid.
There are usually two solenoid valves and tubing systems for these types of fridges. One actuates on demand for water whenever requested, and the other operates automatically to make ice cubes until the ice cube reservoir is full.
Carefully push/pull the fridge away from the wall.
Unplug the fridge from the outlet.
Shut off the water supply to the fridge.
Remove access cover (usually the on the bottom) from the back of the fridge. Follow the tube that comes from the top of the fridge (for the ice maker) down to the bottom of the fridge.
Inspect visually for sources of the leak on tubing and related parts. Carefully check by hand for leaks in areas not readily visible - including the back sides of all the tubing, too. There may be sharp edges that can cut if not paying attention. If a leak is found where the tubing connects to other parts, you may be able to simply remove the tube and cut it back an inch or so if there is enough slack.
It may require that some special fittings and parts be obtained to reconnect and some compression type parts are designed for single use. If this is the case, gather the parts and bring them to a local hardware store for assistance obtaining replacements.
If a solenoid valve is found to be the culprit, due to a crack, etc. a trip to an appliance parts store will be required - unless able to purchase online. Part prices can vary widely , depending on the source.
Once replacement parts have been secured, reconnect after disconnecting power & water supply lines. When satisfied with the installation, reconnect power and water lines and test.
Carefully slide the fridge back into position - taking care to not crush the power or water lines.
Dec 31, 2009 | Freezers
I had a leak in the tubing so we replaced the tubing and fitting going from main supply to fridge after that ice maker stoped getting water but all lines have water its just not getting into the ice maker....
The water inlet valve is on the back where the water supply connects. You may need to remove part of the cardboard backing to see it. There are two wires on each valve. If they are the same size you can swap the wires on each valve and try the dispenser. The water should go into the ice maker so watch it so you don't overflow. If it don't go into it see if the fill tube just behind the ice maker is stopped up with ice. If water does go into ice maker, wait and see if it dumps when it freezes. If it does it should refill with water(swap the wires back). It's an ice maker problem if it don't because you've already seen the valve and line work.
Sep 28, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a Kenmore side/side with water dispenser and ice maker. Ice maker is not making ice, but I still get water. Every once in awhile I see a puddle under fridge (a large puddle). When I pull the fridge...
Hi TJ,
It'll cost around $65.00 to take care of this problem. The problem is the water inlet valve. The part number is 4389177 and can be picked up at your local appliance parts retailer or you can get one online maybe for a better price (just plug the part number into your favorite search engine).
Here's what's happening... The valve I mentioned is actually a "dual coil" unit. One coil supplies the cold water, the other feeds the ice maker. These "coils" are independant of each other, so one coil can fail and the other can keep on truckin', no problem. But what you have is an Ice Maker coil/valve that is weak and it's allowing water to bypass.
Basically the IM valve isn't closing shut completely. Imagine a dripping faucet... that's what it's like except you can't hear the drops, you can only see the results. Imagine drop by drop rising up that tube behind the fridge and into the IM. One drop at a time. These drops of water go into the freezer compartment through the IM fill tube. Now when these little ***** drops slide down the fill tube inside the freezer compartment they flash freeze before they reach the IM. One drop after another... drip drop drip drop. All these little droplets of water eventually form a glacier inside the fill tube.
OK, now we're at the point of glatiation. The fill tube (just behind the ice maker) has completely frozen solid. Now... when the IM "calls" for water to refill itself, the (failed) valve opens up and lets full pressure through. But where is this water/pressure going to go? The pressure builds inside the 1/4" water line until it can't handle it any more, the pressure looks for the path of least resistance. That path is the connection that you found loose. It blew out because the fill tube (into the freezer) is blocked with ice and the reason it's blocked is because the valve isn't shutting off completely.
That's alot of words to say this... it's an easy fix. Get the valve (above). Pull the fridge out. Unplug it. Turn the water off at the wall. Remove the water line going into the valve and set aside. Remove the cardboard panel. Remove the 2 screws holding the valve to the fridge. Pull the valve out. Note the electrical and tubing connections carefully. Get your new valve out and install the electrical and tubing just like the old one. Then rebuild, turn on the water and look for any leaks (use a flashlight and take a minute or two here... finding a leak now will save you alot of misery later). Replace the cardboard and plug it back in.
There ya go! Your first major appliance repair job done successfully? Priceless.
SG
Mar 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water supply
Hi Don,
Cold water supply at Fridge location. Run 1/4" tubing and connectors to match the supply valve and solenoid valve on the Fridge. Should be just one tubing connection.
If you do not have a supply at your Fridge, you can shut off your main supply and tap into the cold water line and run you a supply over to the fridge. use 1/2" PVC pipe and fittings to route over to the fridge. Get a Threaded adapter to connect a shutoff Valve. This way you have a way to keep the main supply on and hook up the Tubing from the fridge to the supply.
Nov 28, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
