Question about Garden
Mower stopped suddenly electricity gets through to motor andblade rotates
    Champion:
  • 205 Answers
Were you mowing wet grass, if so you over loaded or over heated the mower. to high grass will do the same, Is this and electric mower or gas?
Posted on Oct 11, 2009
B&D Elct mower crapped out today,rock?? started making a funny sound. and the same noise with a lttle white smokeLooks like th a belt of some sort under the blade is out of place. Any suggestions?
You've either broke the motors housing moving the motor out of alignment or the impact on the blade has snapped the drive belt by the sudden torque or it's been jerked off by the sudden stop of the blade it's been yanked off the drive pulleys and the nose is the motor running free with no blade resistance you will need to open up and inspect the drive belt assembley system the blade drive shaft pulley access area and the motor access area to either replace the broken belt or refit the belt if it's not been chewed or damaged by the free spinning motor pulley the smoke it was proberbly the belt rubbing against the motors drive pulley or wrapping up around it burning it through friction
Or your broke the motors drive shaft HOUSING allowing the driving motor and pulley to become misaligned dropping drive belt off
The motor funny noise if a banging around sound then is was the still running motor pulley is bouncing around and rubbing against the deck ect. Causing the smoke if this has happened the impact with the stone has caused a kickback effect on the motor twisting it out of its housing breaking it's secure mounts meaning the decks motor is loose the housing has gone, the MOWER extremely dangerous as the motor can at the speed it's running at 3000rpm it will chew thought the rest of the deck in a matter of seconds throwing and ripping itself from the machine sending chunks of broken deck and the motor flying in all DIRECTION possibly causing injuries to any one within range and as the wires rip apart and a possible nasty and even fatal electric shock please for your own safety do not use the lawnmower
Until it's been inspected by qualified personnel
It is highly unsafe and should either be repaired or replaced which ever the cheaper
Advice to check the area your cutting esp when using a high impact resistant plastic deck lawnmower for hidden foreign objects large and small stones as the small ones can be thrown by the blade like a "bullet"! small toys esp metal cars etcetra will make excellent shrapnel and cut the fabric grass box to ribbion it's also you if directly in the debris path Also not good for your lawnmowers blade or deck
Pavement slabs are defiantly known as the silent MOWER DESTROYER YOU can't hear it, as you aproch you can't see it before it's too late, there's a Loud bang the MOWER stops that exact same instant and the MOWER IS NOW KNOWN AS BROKEN "!
Esp on petrol mowers slabs tend to stop the MOWER dead bending the crank shaft the mowers with a slightly bentccrank will jump Round like it's on steroids or vibrate so badly it will shake itself apart as well as leaving a, very odd sensation in your arms
Deposits from animals are just nasty to clean off the deck and wheels so I clear them up too if THERE are any just in case
Jun 02, 2016 | Black & Decker Black and Decker Mm575 18"...
Hi the blades on my E-drive 1200w lawnmower are not turning?
Sounds like you have lost or broken your shear pin out of your drive pulley. Make sure your drive belt is working the way it should be. You did not say if its working.
Mar 19, 2015 | Garden
My 2 year old corded electric Task Force mower whch has had very light use suddenly stopped in middle of mowing and won't restart. Didn't trip any breakers and the cord is fine. Felt cool, not clogged
Sounds like electric motor has gone bad. If you can get past the switch and put a tester on and see if there is any power there that would tell whether your switch has gone bad. I had a new electric motor go bad after ten minutes use. I ended up replacing it.
Sep 28, 2014 | Garden
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
I have a Cub Cadet 1250. The PTO suddenly stopped
Look at www.cubcadet.com. There under parts you should find an IPL for your mower. You will need the model and serial number from under the seat to get the information. Look under the electrical for PTO.
HTH
Good Day.
Oct 29, 2009 | Garden
Motors starts but nothing else happens
Hi
There should be some kind of button and an handle both should be pressed and only then the blade should rotate .
Thats the way it works in my electric lawnmover i guess it more or less the same in all of them .
hope it helps
Jul 16, 2009 | Black & Decker 19" Electric Lawnhog...
Electric mower will not work
the shear pin has broke on the drive shaft put a new one in.
Apr 28, 2009 | Black & Decker 19" Electric Lawnhog...
18" mower suddenly stopped working
motor problem.if you hit something stone our water springler may be the motor magnetic ring broke & jam the armature & not
to start & house pop. see toolpartsdirect.com looks for the model of the mower. black & decker
Feb 08, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
