Question about Nokia N95 Cellular Phone
Distorted sound when using handset to answer calls
When I make or receive calls from my Nokia N95, I have to switch to speakerphone as the small ear speaker is very distorted. It has been submerged in water recently, and this has caused new problems (black screen) but the speaker problem happened before the little swim! I think I may need a new phone as the N95 is now 3 years old.
All you need is a new speaker unit, these cost between £2 and £10 on ebay. remove all 4 screws blow the screen slide bit, carefully pop of the screen surround and prise out the old speaker and insert the new one. Rebuild phone. Fixed.
Posted on Jan 23, 2010
  • M P
    M P Nov 27, 2011
    Fixed sound problem but need to sort out screen problem
Pls how can i flash my nokia N95
No matter what network your Nokia N95 phone currently runs on, you can unlock it---or "flash" it---to run on any GSM network. You will only be able to use your unlocked Nokia N95 phone on networks that use SIM cards---such as T-Mobile and AT&T---and not on CDMA networks such as Sprint and Verizon, which do not provide SIM cards.
Read more: How to Flash a Nokia N95
Unlocking the Handset
Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
Request a Nokia N95 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
Replace the SIM card, battery and cover. Fully charge your handset.
Turn on your handset and type "#PW+".
5
Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
6
Dial "+1#". At this point, the screen on your Nokia N95 should read "SIM Restriction Off."
Inserting SIM Card
Switch your handset off and remove the back cover and battery.
Remove the SIM card.
Insert the new SIM card into the SIM card slot. Now that the phone has been unlocked, this can be a SIM card from any U.S. service provider that uses SIM cards.
Replace the back cover and battery and switch the cell phone on. The screen should now read the name of the new service provider
Nov 30, 2011 | Nokia N95 Cellular Phone
I can't hear calls to the n95 nunless i use the loudspeaker
Your phone's Ear Piece must be damaged.
You should take it to a service enter and they will have it replaced.
If you have a Head Set, you can also use it to mae and receive calls.
Thank you for using Fixya,
Kenneth
Feb 13, 2010 | Nokia N95 Cellular Phone
Sound is terrible, except speakerphone
Hi!... You need to replace the ear speaker of your phone and it will be okay.
Oct 01, 2009 | Nokia 2600
How to use N95 nokia ear phones remote, to answer call
when someone calling keep plugged in your headset sometimes it will work
Sep 18, 2009 | Nokia N95 Cellular Phone
No tone unless speaker is used.
Have you changed the fasica? if so you may have disposed of the speaker as it sits in the old fasica
where the grill is
May 22, 2009 | Nokia Consumer Headset
Panasonic Speakerphone base station makes noise when handsets use
Cut the wire to the speaker in the base unit. Problem solved.
I have a Panasonic KX-TG6074b phone as well, and it does the same thing. In addition I can not understand the digital voice that announces who is calling. Therefore I came up with a very simple solution to buying a new phone, because the rest works great. I cut the wire to the speaker. The only other solution in buy a phone from a different manufacturer, because Panasonic's quality stinks.
Mar 13, 2009 | Lands Phones
Nokia95 - 1G card
try network settings change dual to gsm mode
Oct 02, 2008 | Nokia N95 Cellular Phone
Bluetooth connection not working Kenwood KCA BT100 with KDC W7537U and a Nokia N95
Well... I'm sure mine worked ONCE! I have the BT100 and KDC-W7534U. It worked fine with my Nokia N80 but with my Nokia N95 It connects fine but i cant hear or be heard when the call is answered.Interestingly I cannot use the headunit to dial a number anymore. If i was to be on a call BEFORE connecting the headunit then it works. But once the call ends and i select an input source - the phone has the same symtoms as above again. I have checked all the profile settings and set the enhancment to be active on the active profile. I thought Bluetooth was a standard and it was just meant to work if it was bluetooth compliant! ...Grrrrrr!
Jul 26, 2007 | Kenwood KCA-BT100 Wireless Headset
Nokia N95 Cellular Phone Logo
196 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
