Question about Desa International Unvented Gas Space Heater
I have a DESA unvented gas fireplace. Lost remote.
LMFP33NR/LMFP33PR Remote control gas fireplace
system. I have lost the remote control. Where
can I find a new one. Mary
  • 4 Answers
SOURCE: desa ventfree gas heater
needs a new thermocouple :)
Posted on Feb 05, 2009
  • 232 Answers
SOURCE: I have a gas log fireplace with lmfp33pr log unit.
did you put new batteries in both the remote and the remote sensor box . if so you will need a new remote you can buy for about 100 bucks it includes the remote and remote sensor, its not hard to install . any gas log supplier can assist you
Posted on Dec 04, 2009
johnrodgers1
  • 80 Answers
SOURCE: I have a gas fireplace with remote...the brand is
check batteries in both remote and the receiver underneath F/P, check to see that wires from receiver are still on gas valve and are tight, you also can reset you remote, butthis is a sequnce that depnds on brand
Posted on Feb 06, 2010
  • 10 Answers
SOURCE: I BOUGHT A USED UNVENTED
Check manual, get LP conversion part number than order. If no manual look online under the model number and look up.
Posted on Oct 05, 2010
  • 59 Answers
SOURCE: I have a DESA gas fireplace that I would like to
go to skyteck they have a stat called 7003p wireless stat fro millivolt systems
Posted on Oct 12, 2010
Testimonial: "thanks"
I have a DESA LMFP33PRB unvented fireplace. The remote controls the on/off and all the other functions, but it will not control the flame control, "the part that you can lower the btu and raise the b
You may have a bad receiver that has lost its ability to control the servo motor and adjust the flame height. Part#111441-02 Proflame Receiver. It may also explain the poor reception.
Nov 30, 2012 | Heating & Cooling
Cant start gas fireplace
  • Find the remote's receiver under the fireplace.
  • There should be a switch to change from "remote" to "ON".
  • Turn the switch to "ON", if the fireplace ignites, you may need to re synchronize your remote. If it does not, your remote control may be bad.
  • Bypass the remote to ensure your fireplace is operational by connecting the "TH" and "TP/TH" terminals on the valve with a wire or paperclip. If the fireplace lights up fine, then it is for sure a bad remote.
  • Universal gas fireplace remotes can be found HERE.
Oct 28, 2012 | Empire Comfort Systems Empire Tahoe...
I have a Desa EFP33PR ventless fireplace. In Auto it works just fine. In Manaul the pilot will light but when I release the gas valve control knob it goes out. Some times, if I rotate the control knob...
It sound like you may need to clean the pilot on the fireplace and then reseat the thermocouple.
Here is a link you may want to look at:
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Sep 13, 2011 | Desa International Unvented Gas Space...
I have a gas log fireplace with lmfp33pr log unit. The remote wont work. They have new batteries. The manual swirch will work. What do you think the problem is?
Dec 03, 2009 | Desa International Unvented Gas Space...
I cannote get my remote to operate the fireplace. I have installed 3 new batteries and it still does not work.
The remotes are often a problem...I would advise against repairing it....sometimes the sensor for the vent isn't visible enough for the remote...the wires or sensor can be melted....The best/cheapest solution is to run a wire from the same two contacts the remote sensor are hooked up to on the gas valve...and install a switch on the wall....Turn the fireplace on with the flick of a switch....a Thermostat can also be connected to operate the fireplace using the same contacts as the remote
Oct 26, 2009 | Desa International Unvented Gas Space...
While the pilot remains on and the remote control seems to be working, I think there's a problem with the connector box in that I don't hear a beep and it doesn't ignite the fire. I changed batteries and...
The remotes for gas fireplaces are lousy and cheap...I would try going to the gas valve on the unit and take a small jumper wire.....jumper the connections the remote are hooked up to...if the unit comes on and runs normally trhats the problem....you can run 2 wires from those same terminals to a switch on a wall and operate it that way...more reliable
Oct 17, 2009 | Desa International Unvented Gas Space...
I replaced the battery in our HRC200 handheld it still does not work. We can turn the fireplace on with the manual control at the logs. The fireplace was used last season for the first time. Can you help?
The remote works once the right room temperature is
sensed (66F) by the remote, This is a room temperature
triggered remote.However, if the thermostat at the
remote becomes defective, then there is no way that the remote will function. You have to do it manually.
Oct 13, 2009 | Desa International HRC201-4 Remote Control
Need instructions to my transmitter
I have the same problem. The company is out of business DESA Heating. I have been unable to find a solution. FMI bought part of DESA but can't get any help there either. 1-866-328-4537
Jan 18, 2009 | Heating & Cooling
Heating & Cooling Logo
903 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
vance jones
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
