I have a maytag top loader washer and when it is on the spin cycle the whole drum shakes hitting the walls of the washer
    President:
  • 1,937 Answers
Without having the model number, it is difficult to diagnose.
Most Maytag / Whirlpool top loaders use a set of balance springs and friction pads to buffer the shaking.
Here is a Whirlpool site with a number of PDF files on their products including troubleshooting sections.
Find your washer under laundry products and open the PDF, it will probably take a few minutes to load.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
Posted on Sep 27, 2009
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
My MAH9700 Front Loader washer is shaking a lot and making a loud banging noise when spinning.
unscrew the 4 screws inside the detergent dispenser and lift the top and see if the counterweight on the tub is loose,otherwise it may be the drum bearings going bad on the inner drum
Apr 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
Washer does not turn or spins
the pumps and motor pullys go bad on those.tip washer back against wall and inspect there.motor pulley melts ,the pump pulley breaks loose from its spot welds and then will rub metal to metal.when ordering parts replace belt too if damaged.if worn wont get a good spin and then dryer has to work over time.[power bill up.up,up.thanks for using fixya.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV7260B Top Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
349 people viewed this question
Top Washing Machines Experts
