Polaroid FLM-2632 Television
Problem for Polaroid FLM-2632 Television
FLM-2632 October 2006 Won't turn on, no red light, fuse OK
By cgk4 on Sep 27, 2009
FLM-2632 October 2006 When set was off but not unplugged I disconnected a DVD player. At that point the red light was on, but after the disconnect there was no response to the side on-off switch or remote on-off. I unplugged and replugged the set. No light at all. Left it off for an hour or so, no light, no on, no off. The fuse next to the power inlet is fine. I found http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen#
and thought I'd follow the path there, but now apart, I see no bulging capacitors, and the layout is different from that website's pictures. Advice welcome!
Solution #1
posted on Nov 24, 2009
Not Rated)
Fryertuc
Rank: Master
Rating: 97%, 5 votes
Are you able to with the back off check on all of the PC board 'Especially the power supply board' if any of the fuses are open. If you have a multi-meter to test would be the best. Sometimes you are unable to see the open in a fuse with your naked eye.
This still may be a main power supply issue but more than likely just an open fuse.
Blessings,
A/V Media Tech Guy
Was this helpful?
Yes
No
Popular Solutions for Polaroid FLM-2632 Television
Questions and Unsolved Problems for Polaroid FLM-2632 Television
Do you recommend Polaroid FLM-2632 Television?
Answer
Answer
v chip issue: please help! polaroid flm-2632. we moved the tv from the living room to the bed room... (More)
Answer
is a polaroid FLM 2632 compatable with PS 3
Answer
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as... (More)
Answer
polaroid 42" Flat Screen says no signal
Answer
poloroid flm15168 what is the code so my directv remote will operate the TV also?
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in Surprise, AZ
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
