Question about Gateway GT5662 Desktop PC
When I start my computer it says no input signal and I do not get a picture I can hear the tower running and the power light on my screen is on how can I fix this it is a gateway model GT5662
  • Gateway Master
  • 8,404 Answers
Your video cable is (1) disconnected (2) faulty or you have selected some other mode other than what has been set in the BIOS.
The message if from your monitor
Check it out.
Posted on Sep 27, 2009
My hp envy 20 wont turn on
Need some more info:
Does the screen come on?
-What is on the screen?
--What happens when it fails?
Does a light come on the tower?
-Does a light come on in the power supply (where the computer plugs into the wall)?
Do you hear any beeping?
Do you hear any fans going?
Does the power supply fan (Where the computer plugs into the wall) try to start & fail?
-Or does it not try at all?
Apr 28, 2014 | HP Computers & Internet
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
Olevia 242 TV.... No picture or sound!!!
A blue screen usually is present if no signal is connected to the set---hook a DVD up to one of the rear inputs--select that input and see if have picture and sound.
If that works connect cable or antenna to set and select that input
NO signal is like no gas in car---it will not run.
Mar 22, 2012 | Televison & Video
When I turn the computer on it goes into digital power save and windows does not load
The monitor is going into power-save mode because it's not receiving a video signal from your computer. Are you turning on the computer at the monitor or on the tower? If you're turning the tower on are you hearing any noise (i.e. fans running, beeps, drives spinning, etc.)? Does the power light on the tower come on and stay on? If not you may have a bad power supply or other hardware issue.
May 02, 2011 | Computers & Internet
I have been given a working dell fp1500 screen, have plugged it into my desk top, screen is reduced but working and displays a sign no video input. Is this simply not having the right driver or do I need...
Heres what you do: Open up your tower. Take out the ram sticks. Put them back in. Make sure there is no power when you do this. Close your tower restart you computer with the monitor connected. You should then recieve a signal.
Mar 23, 2011 | Computers & Internet
Emerson 42 inch television flat screen HDTV: i connected a DVI to HDMI cable to dell computer screen to television in order to display computer screen to it but the signal isn't working, how do i...
Your Dell Monitor does not have a video output. The DVI/HDMI cable needs to run from the DVI-Out of you computer tower directly to the TVs HDMI input, ideally one with a red/white analog audio input next to it, because that cable only provides a video signal. If you don't have a DVI out on your computer, perhaps your TV has a VGA input. If your computer/video card only has one monitor connector, then you can only connect the Monitor OR the TV.
Dec 27, 2010 | Emerson Televison & Video
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Monitor wont display a picture
plz try by resitting the ram if it doesn't work then *********** board require servicing
Mar 16, 2009 | Microsoft Windows 98 for PC
Monitor has a message input signal out of range
then.. we can clearly say that there is a problem with the tower... check for the proper power supply to the Tower... and check for the lights comingup on the tower or not..
Aug 24, 2008 | Compaq Computers & Internet
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Gateway GT5662 Desktop PC Logo
161 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
