Cd not reading
My cd won't play. it says no disc My Polaroid PDX-0073: 7" Portable DVD player will not read DVD's anymore. It says no disc. But when I play a music CD it works fine. Missed the 90 day warranty by a couple of weeks. Neither Target or Manufacturer will stand by the product.
  • kinha Jan 04, 2008
    my dvd don,t play nothing the screen is all black the disk spins but say no disc.
  • 3 Answers
Hello
I had that problem, the problem is that where you put the disc (the black Circle) tends to get a bit loose so it moves downwards.
so the distance between the lens and the under surface of the DVD / CD is reduce, so the beam is NOT return to the lens.
The way I fix it is by pulling the black circle EXTREMELY carefully and SLOWLY while you are turning it.
Once is out, with a toothpick or a needle put a small amount of crazy glue in the inner walls of the hole that is in the center ( where the pole of the rotor goes in) this way the hole is reduce.
Wait till it dries, then gently put it back in, it will be a tight fit, IT MOST NOT GO ALL THE WAY IN!!!
By this i mean that you will see the pole of the rotor go into the hole, but it most not reach all the way, it should be below the surface. The distance between the end of the pole and the surface of the black circle should be THE THICKNESS OF THE BLACK CIRCLE.
The way to know that the distance is right, put in a CD and play some songs, then try it with a DVD.
If it reads no disc it means you inserted the disc to much, pull it out a bit, then try again.
Once it reads both CD and DVD, fill in the hole with a drop of crazy glue, this way the black disc will not move anymore.
One more thing, I do not recommend to use alcohol in the lens, 'cause some lenses are now made of polymers non resistant to abrasive, instead use a cue-tip (cottonete, little pole with cotton to clean your ear) moistened with bottle water or distiled water.
Note MOISTENED not soaked or wet.
Hope it works for you.
Best Regards
Luis.
Posted on Dec 29, 2008
    President:
  • 4,402 Answers
You might have a weak laser, i also had it where the spindle was not sitting correctly (to low) from the cd top being closed.
Posted on Dec 18, 2007
Polaroid portable dvd player won't recognize disk
You have put a dirty CD in and now the laser lenses is dirty and cant read the finer details of a DVD.It needs a clean.
Dec 06, 2013 | Polaroid Televison & Video
Polaroid Portable DVD player PDX-0758 reads bad disc for all dvds
the only way is cleaning the optic reader.Just wet in alcohol a swab -almost dry- and clean it.If this does not fix the problem,you may have to replace it.
Feb 15, 2010 | Polaroid Portable DVD Player PDM-0822BD
Sound when playing a CD, nothing when inserting a DVD. It constantly reads 'No Disc'
the laser pickup is bad and needs replaceing it is cheaper to replace the unit part is so hard to find
Dec 02, 2009 | Polaroid 7'' Portable DVD Player
All discs won't play and reads out "bad disc"
try cleaning the lazer of the device..
are they copies that the device cant read
I.E burn to fast harder to read burn at 2x easier to read.
Sep 27, 2009 | Polaroid Portable DVD Player PDM-0722
Dvd not playing
2008 EXCHANGE MODELSNO PARTS FOR SERVICE
Aug 20, 2009 | Polaroid PDX-0073S Portable DVD Player
Rca drc628 portable dvd not reading disc
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 12, 2009 | RCA DRC629N Portable DVD Player
My portable dvd player is not working good
It sounds like U have a bad lens. Try a lens cleaner. If it is the lens, it wont read anymore discs. Sometimes it will also make a clicking sound and show disc error/no disc cryptic messages on the screen.
Dec 23, 2008 | Polaroid PDM-1058 Portable DVD Player
Polaroid portable dvd/cd player PDX 0073 Model No: BT-6025 When I put in a disk and turn it on it first says "loading" and then it says "no disc".
Hello
Best Regards
Luis.
Jun 29, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Polaroid PDM-0711 DVD player won't play DVD's but still plays CD's
I've got the same problem, I turn my player on it's side until it reads the disc. more of a band-aid solution.
Mar 28, 2008 | Polaroid 7'' Portable DVD Player
Polaroid PDX-0073 7 LCD Portable DVD Player
Hello
Best Regards
Luis.
Mar 16, 2008 | Televison & Video
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
