Question about Electrolux Refrigerators
Frigidaire gallery fridge model glhs269zdw1 not working after power surge..fridge lights are on and I can hear fan running..the water dispenser also stopped working.
  • 146 Answers
You are hearing the evaporator fan in the freezer but not the compressor motor, therefore no cooling. This is a classic symptom of a bad control board - you will need to check and replace the circuit board ! best of luck
Posted on Sep 27, 2009
Replaced water filter, dispensing valve on frigidaire gallery side by side still no ice or water
It may very well be frozen. Some of those fridges have problems with the line freezing because of the way the line runs. The one way to tell would be to empty fridge, unplug, and let sit to thaw. Opening freezer/fridge doors will shorten the process. You can Google your exact model number also, and find out how your lines run and use a hair dryer on that location.
Mar 07, 2016 | Frigidaire Refrigerators
Frigidaire gallery freezer fully thawed and red light never came on.
So lets start with this do you hear any clicking noises coming from behind the frig? Can you hear the fan running in the freezer? Does the frig cool at all?
Sep 25, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
My 7-button Frigidaire Gallery ice/water module is not lighting up and not functioning. No ice or water is being dispensed. Wiring harnesses seem to be all intact.
Hi
If freezer door switch is not working, dispenser won't work. Does the freezer light go off & on when door is opened & closed? If you have a voltmeter, check that water valve is getting 120 volts when dispenser is pushed in. If no voltage, I would suspect the micro-switch that you hear clicking when you push in with a glass. Even though it clicks, the contacts could still be bad in it. However other than that loose/off wire, ribbon cable for front buttons off/loose, bad board, child lock are something that can make the dispenser dead.
Please check the bellow link if it helps:-
http://www.ehow.com/how_6494535_troubleshoot-frigidaire-icemaker.html
http://www.ehow.com/how_6557721_troubleshoot-frigidaire-refrigerator-icemakers.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Power in house went out for 6 hours now the coil is cooling but fan not running
Your defost timer control board may have burned out from the power surge.I think they are electronic defrost on there models.If not you may need a compressor relay kit.Yuo can get the parts using your model # at your local appliance parts store.
May 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser leak
I
It appears that you hace a water valve problem.The valve has been contaminated and needs to be replaced
Oct 13, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser not working & fridge and freezer not getting cold
okay, most likely, your problem is your fan motor, its making your evaporator becoming a block of ice freezing your water lines but its not circulating the cold air through your refrigerator. remove the panel from inside the freezer and see if it has become a big white block of ice and the fan motor is turning. some fan motors will not work with the door open so you must manually press the light switch and see if the fan is blowing air.
if fan blades are not turning, replace the fan motor. but if it is blowing air and there's a big block of ice, unplug your fridge and let it thaw out. if after melting your fridge is running again, there's something wrong with your defrost system. that means check and replace your defrost heating element, defrost thermostat and or defrost timer.
i hope that helps with your problem. good luck!
Jun 10, 2009 | Frigidaire FRS23H7CS Side by Side...
MAKING ICE BUT ICE AND WATER DISPENSER QUIT WORKING.
Sounds like a plugged water filter, assuming the water is turned on to the fridge. If you have a manual, refer to the section about water filters. The filter is usually accessible from the front of the fridge at the bottom....requires about a 1/2 turn counter-clockwise. Some units require that the water be turned off first but not all.
If you do not hear a click when activating the dispenser, there could be an issue with the water solenoid (water valve) that opens and closes when you use the water dispenser....agai...check the manual if at all possible.
Apr 17, 2009 | Frigidaire Refrigerators
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
150 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
