Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Water drains but no water comes in
Water has draned but no water comes in when door closed and machine starts
  • 6,784 Answers
HI. this is a water inlet valve issue. i recommend testing this device. it may be faulty.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first. If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
**(((If the inlet proves to be functional with no leakage, this will lead to the control. its has failed in thsi case. replace it asap)))
Posted on Sep 27, 2009
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 | Dishwashers
Tip
How to get your washer to work when it does not spin or drane
go to the fillter at the front of the mashine and turn it to open, make sure mashine is turned off.put a bowl or plenty of towels down let the water drane out then clean the filter out.put it back in close it and away you go
on Feb 16, 2010 | Washing Machines
Why does drain motor start when pushing the start button on the door before the door is closed?
It's almost certainly the float switch in the bottom of the machine. In the bottom is a polystyrene 'float' that is either active due to water in the bottom or is faulty. Tip your machine to the side and remove water and try again, bridge or replace switch is also an option
Jul 07, 2013 | Bosch Dishwashers
LG washer
water is not draning open the drain filter and check if something is stuck on the pump if if fails replace the drain pump.
Jan 18, 2013 | LG Washing Machines
I have a beko washing machine model wma 652s and the start/cancel button keeps flashing. It happened when I started a programme when I pressed the start button the machine failed to start. I've...
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
In this case the machine must start up to open the inlet and let the water in. If not this must be checked,If possible swap a board and check to confirm.
Once the inlett opens then the water flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Aug 18, 2011 | Washing Machines
The machine is not draining water - it starts the washing cycle, takes in the powder and churns around but then stops when it needs to drain the water. If I empty all the water out, it will then spin the...
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Asko W6021 Front Load Washer
How make the door open automatically when finish the laundry
Welcome to FixYa,
These model of Asko ( based on the number listed ) do not have such an option. On these models the Program Control knob must be at the end of a program (at the 12:00 or zero position) to open the glass door.
If you need to stop or interrupt a program after you start the machine, turn the Program Control knob
to 10 (Drain). Any water in the machine will be pumped out and you can then press the Door Open
button ( ) to open the door. To restart the washer, close the door and turn the controls to the desired
settings.
On the electronic control models, if you need to open the glass door during a wash or rinse cycle, press and hold the Door Open button for three seconds. The machine will stop and automatically drain enough water so the door can be opened safely. The program will resume when you close the door. The inlet valve will come on to
ensure the proper water level.
In case of mechanical failure, you can use the Emergency Door Opener located by the drain pump. To use the Emergency Door Opener, remove the screw holding the cord handle (loop) and pull the cord down.
Hope this answers your question even if it isn't necessarily the answer you wanted. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Front louding not running . Whirlpool
You need to get inside and clean out pump assembly
Jan 14, 2010 | Whirlpool Washing Machines
My washing machine will not hold water
Make sure your drain is at the proper height. Here is a photo for reference. The water draining straight thru can be caused by this. If this is not the problem, please let me know. Hope this helped and best wishes.
Sep 13, 2009 | Washing Machines
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
95 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
