Nikon COOLPRINT Thermal Printer
Problem for Nikon COOLPRINT Thermal Printer
Printer won't communicate with computer
By srex on Dec 18, 2007
Hi! I'm quite puzzled by a printer/mac problem I have.
About six months ago the printer (an Canon Pixma IP4200) suddenly stopped printing. I have a powermac G4 tower (running on OSX 10.4.10 at the time). I thought it was the printer, so I took it in and was told it was ok--that it printed fine for them. Indeed when I got home I hooked it up to an older G3 (running 10.3.9) and it worked perfectly. The only thing I could think of was that an OS update possibly did something. I have since updated again (to 10.4.11), hoping that would undo something, but no luck.I have literally spent hours on the phone with both Canon and Apple and neither could solve the problem. I have checked cables, ports, downloaded and installed new driver, logged in as a root user, etc. and nothing gets more than a test print from the printer. (It shows up in the USB chain in system profiler.) Any suggestions would be most appreciated, as I'd rather solve the problem than go out and buy another printer which could suddenly do the same thing!
Thanks in advance!
Solution #1
posted on Apr 26, 2009
Not Rated)
craigjamesbt
Rank: Guru
Rating: 86%, 33 votes
go to system preferences select print and fax locate the printer in the list to the left and select the minus symbol underneath then restart the system. after rebooting go back to system preferences select print and fax connect the printer and click the add symbol under the list select the ip tab which looks like a globe if the printer doesn't pop up in the ip list you must use the default ip address which should be 192.168.1.1 but if that is not it you will have to contact support again to find out the correct address once you find it in the add print fax you just select add then select it in the default printer drop down menu at the bottom of the screen and you should be ready to print
Was this helpful?
Yes
No
Popular Solutions for Nikon COOLPRINT Thermal
Questions and Unsolved Problems for Nikon COOLPRINT Thermal
Do you recommend Nikon COOLPRINT Thermal Printer?
Answer
Answer
it says i have to download a high speed usb controller for my wireless usb adapter for it to be... (More)
Answer
On IMac OS 10.4 The printer gave me the choice of printing both sides. On )S 10.6 that choice has... (More)
Answer
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon COOLPRINT Thermal...:
Top Printer Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
