Question about Watts Onan Portable Generator - 4000 , Model# 5500
Need a wiring diagram for an Onan 4000 generator
  • Tech4You May 11, 2010
    What model?
4 Suggested Answers
joboo1
  • 257 Answers
SOURCE: onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Posted on Mar 02, 2009
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
  • 6 Answers
SOURCE: Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Posted on Sep 28, 2009
Wire diagram 0611-1267 or service manual - Onan Microquiet 3600 & 4000 Generator
Found this manual on the internet
1103_ky_spec_p_install_2015.pdf
It seems to have wiring diagrams.
Is this OK?
Nov 15, 2017 | Electrical Supplies
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
Onan 4000 generator has no spark
If there is no spark, the ignition module may be bad, or the wiring to it. Have the module ohmed out. Also the magnetic trigger assembley that is on the rotor that sweeps past the ignition module maybe broken. If they check ok, suspect the control board
Mar 23, 2013 | Onan Microquiet 3600 & 4000 Generator
Oil is being pulled from valve cover to air filter on my onan microquiet 4000 generator, what do I need to do?
63525c2e-e749-4a53-8402-d0463bb6c753.jpgThat sounds like the reed valve sticking or dirty.
You will need to take out the reed valve, clean and re-install. Be aware that a small amount of oil is common, also do not over fill the oil. The full mark is hot. Too much oil in the crakcase can build up pressure and keep the reed valve open.
Aug 22, 2012 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Apr 04, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,594 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
