Question about JVC Cybercam GR-D70 Mini DV Digital Camcorder
Mini-DV TRAY OPEN..Camera shows E-04 Problem Code
Tried new battery..tray refuses to close. Any ideas?
  • Anonymous Dec 18, 2007
    THANKS CTF..I gave you a TOP RATING for effort..But, We are both already on the same page..I only insert the battery and tape prior to use;my battery is JVC (as are all of my tapes)..AND...I have already soldered the leads of the sensor together...Still the tape tray remains STUCK! I cant get the case open to try a HARD REBOOT...What other ideas can you suggest?
  • gtmurphy Jan 17, 2008
    Does anyone know IF there is a FUSE controlling the opening and closing of these trays? I just picked up a GR D33 with the same problem..also a non-working LED light. Better yet: Does anyone have a REPAIR MANUAL for the GR D33...which shows the location of internal parts and describes what the circuits do.
    New Friend:
Try backing over it with a pickup truck, You will never have this problem again, guaranteed.
Posted on Dec 18, 2013
  • 4,402 Answers
FIrst, tap the side of the camera with a good thump, and it will remedy the problem immediately.
Then, to prevent it happening again, do the following:
1. Chuck out all those cheap crappy tapes you purchased to save a buck. Get JVC or Panasonic.
2. Chuck out all those cheap generic batteries you purchased to save a buck. Get JVC
4. ONLY AFFIX BATTERY AND FILM IMMEDIATELY PRIOR TO USE. Keep both in their proper containers.
if that doesnt work
i'll tell you the secret. the moisture sensor is a little black square on the side of the drive motor. if you look directly where the tape goes in, the drive motor is in the far back left. it's partially hidden behind a silver pin hanging down from the black plastic cover that goes over the video head. take a long q-tip and dip it in glass cleaner(windex etc) and gently wipe it off. you should see a small amount of black guck on the q-tip.
then remove power for about one minute and allow to dry. it's better to use air to dry it out.
Posted on Dec 18, 2007
  • Cary Farah
    Cary Farah Dec 18, 2007
    Go to jvc web page goto support and look see if theres anything else you can try
  • Cary Farah
    Cary Farah Jan 18, 2008
    look for a little fuse it will look kinda like a resister most likely on the board where the battery connects
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
My camera wont charge in the tray or the charge light won't come on. Camera keeps saying low battery.
My guess is that with the age of the battery it isn't able to hold a charge anymore which means you'll need to purchase a new battery. Your best bet for that will be to go through Sony or the website Dr. Battery.
May 11, 2011 | Sony DCR-HC52E Mini DV Camcorder
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
Wont load tape
HI, this is a mechanism fault beep you are hearing. the mechanism and load motor is damaged. you will need to send this unit to the Handy cam repair depot for this repair. you will need a new load motor and loading dock mechanism as well.
Jun 03, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Nov 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens. 2. Press the following buttons in sequence: 2, 8, 1, 2. 3. TV displays "Region 2" 4. Press the Enter button on the remote until code changes to 9 5. Press the Open/Close on the remote. DVD tray closes. 6. Press Power on the remote control. Now code free...
Feb 19, 2008 | Televison & Video
Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Feb 01, 2008 | Canon ZR85 Mini DV Digital Camcorder
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
The camera rejects the tape, I can´t get it in
Have you tried a different tape? are you going from outside to inside? might have condensation just let it sit for an hour.
Dec 03, 2007 | Panasonic AG-DVX100B DV Digital Camcorder
JVC Cybercam GR-D70 Mini DV Digital Camcorder Logo
75 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
