Question about Nikon COOLPIX L3 Digital Camera
I have a D5000 Nikon and a Panasonic SD/HC 4GB card. I have formatted the card and taken a number of pictures. I have loaded the necessary soft ware supplied with new camera but cannot download any pictures.The computer is ok as i can download pictures taken on my wifes Casio EXLIM. Any pictures I have taken can be played back on camera and can also be played on a KODAK Digital Frame, My computer is a "DELL" Dimension 9150 HELP Regards John
    President:
  • 423 Answers
If you are using a card reader of some sort (other than using the camera to download the images), it may not be SDHC compliant. Have you tried using the camera to download the images via the supplied cable? If you've taken the images in RAW format, that could also be the problem. Try using a 2gb or smaller card in the camera to take some images and then download them using your usual method. If it works with the 2gb card but not with the 4gb, it's likely your reader isn't SDHC compliant.
Posted on Sep 27, 2009
I have two sd cards that are brand new on is a pq1 4GB sd hc and the other is a pny optima 2GB sd when I put them inmy camera it says filesys e00100 what is it?
I own a Nikon D5000, that has a 'pqi 4GB SD HC' memory card inside.Within this camera is also something called movie mode, in other words I can record short movies. Now here is the problem, Nikon says how much I can record on the memory card, depends on the speed the memory card records. According th them, I can only record 5 minutes on a 2GB memory card. Does that sound right to you. P-l-e-a-s-e I need help in understanding this.
If this is true,......what side memory card (HD if possible) would I need to record 30 minutes in the movie mode. Thank you so much for your help.
May 16, 2010 | Cameras
I tried to use a card reader to load pictures onto my computer and now it won't load or work in my camera. did i loose my pictures?
yes you lost the file,this is caused due to again and again veiwing the picture being taken,or due to virus in the card carried from system.
solution is you have some recovery soft ware in the net search for it and recover the photos.
kalpana,
chennai
Jan 08, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
I have a canon powershot SD400 elph. Camera menu
Dec 12, 2009 | Canon Cameras
I'm useing the pny optima sd/hc 60 hd 4gb scan disk! it has photos on it useing the camera,nikon coolpixl20. using nikon transfer does not load pictures on computer.
I had same problem. Neither computer nor printer would recognize the SDcard. I took the card to Walgreen's and the card was read just fine. I suspect that we are running XP and do not have the right driver; but I can't seem to find the right driver. Morgen
Dec 07, 2009 | Nikon COOLPIX L10 Digital Camera
I have loaded a new memory stick and get a message "memory card error" I have since tried another card and get the same maessage. Any idea waht the issue is.
Well if your camera is an SD600, I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 17, 2009 | Canon PowerShot SD600 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon powershot A620 - putting a a memory card and it says memory card locked - it's a new card and it's not locked - what should I do?
Oct 24, 2009 | Canon Cameras
Formatting a sandisk 4g to work with coolpix 7900 camera
sd hc cards are not supported by 7900, you will never can use such a 4gb card with this camera
May 19, 2008 | Nikon Coolpix 7900 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
