Question about Kodak EASYSHARE Z1285 Digital Camera
I cant get the usb into the camers - Kodak EASYSHARE Z1285 Digital Camera
My pc wont recognise my camers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Aug 25, 2012 | Fuji FinePix S3100 Digital Camera
I cant save the photos in my PC
Connect the supplied USB cable from your camers to theUSB port on your computer.
The computer will see the camera as an external storage device or anexternal mass storage device, you can then open the photo folder on your camera and copy the photos to your computer.If the photos are stored on a mini or micro SD memory cardthen -An alternate method is to remove the SD memorycard from the camera and insert it into an USB card reader then connect itto the USB port on your computer. Youcan then open the photo folder on the SD memory card and copythe photo to your computer.
Mar 27, 2012 | Sony DSC-T70 Digital Camera
I'm not able to transfer my pictures from camer to
my dear friends
install the Usb driver in your PC
or install the camera software via its CD if provided other vice from internet
enjoy
May 15, 2011 | Cameras
How do I download tapes to my computer (microsoft
Make sure USB Streaming is enable in camera settings menu, that will enable computer to see your camcorder.
Thanks.
Jun 03, 2010 | Sony Handycam DCR-HC24E Mini DV Digital...
I cant take the pictures off the card
hello sir mere camer sumsungh camer ki flase aur who on na off hota hai es ka repia chanter btye new dehli kha par hai muje email kare ved_parkash250@yahoo.com1a4fbf0.jpg
Jun 20, 2009 | Polaroid I533P Digital Camera
Does not work when cpnnected to the external USB hub. Says "Camers Off". Works OK when connected directly to MacBook USB port? Why?
Make sure your USB hub is working. Confirm by using the with other applications such as connecting your thumb drive or other connections. If other connections will work, then your external hub is okay. Other thing, if your usb hub runs at lower speed than 2.0, new gadgets connection may fail.
May 14, 2009 | Logitech Webcam
I am looking for driver for my camer Logitech IM
go to "Download YourDriver.com/Logitech" Hope this helps,
May 10, 2009 | Logitech Quickcam IM 961361-0403 Webcam
My laptop camers has stopped working, does not load
my night vision USB PC(vimicro-301Neptune) camera Model-IT- 305WC stopped working Earlier was ok for >6 month. Now itis asking for New software. i am on windows XP.Pl help on software/hard ware. down loadRegds.vachaspatiSharma
mithusha@vsnl.com
kompgas@yahoo.com
Nov 20, 2008 | Computers & Internet
Cant find pics
The simplest solution is to buy a cheap SD card reader and connect it to your computer. Then put the SD memory card from the camera in the reader. Windows XP will open a dialogue window asking you what you want to do with the pictures.
The caa-03040s has a relatively slow USB connection. Get a USB 2.0 card reader and connect it to a USB 2.0 port on the computer for much faster download speeds than the camera is capable of.
Apr 28, 2008 | Polaroid CAA-03040S Camcorder
Kodak EASYSHARE Z1285 Digital Camera Logo
21 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
