Question about Randell (84111NPCB)
Temperature control we have a randell pizza prep table, model dpm102r...the problem we are having is that the temperature is fluctuating significantly. It has been filled with freon 2x, they checked for leaks and none were found. We have been told that changing the thermostat might take care of the problem or maybe put in a timer. Is there any way we can adjust the thermostat ourselves? what setting would we need to put it on. At what PSI level should it be?...In the part where the coils are(is it the cooler?) there is a pipe, is it normal for this to be hot?
  • Dennis Boxerman Jul 20, 2010
    Let's start with the obvious. The refrigeration system is a sealed system. If freon has been added 2x, there has to be a leak. It must be found before you put any money or time into anything else. If you don't you will be replacing parts and the system will still leak it's freon out and not work right. Start there first. Get another tech to search the leak. It's got to be there unless it was improperly charged the first time.
  • Randell Master
  • 1,230 Answers
go to this web site and check out the manual. It has some general info that can get you started on narrowing down just what is happening.
If it has been filled with freon 2x, there is an issue. Either it has a leak and it has not been found yet, or the amount of freon in the system is incorrect.
Usually, adding a timer is for defrosting purposes. Is there a frosting up issue?
It could be a thermostat issue but it is not set by the PSI, but by actual temperature. If it is a control that you have to set the PSI, an experienced refrigeration tech should know what to set it at.
Let me know if I can be of any further help.
Posted on Dec 20, 2010
  • 122 Answers
Sounds like your unit may be over charged with gas. The pipe feeding the coil should be warm, not hot. It's the smaller pipe that feeds the coil. If it is more than warm the case is over charged with gas and/ or dirty condenser. If box is not leaking gas freon should not have been "filled" 2x. Sounds like you may have an erratic temp control s well.
Posted on Oct 01, 2009
What can i get wiring diagram for TPP-67 pizza table?
TRUE TPP-67 SPECIFICATIONS Pdf Download. - ManualsLib > ... > True Manuals > Kitchen Appliance > TPP-67
True TPP-67 Food Prep Tables: Specifications. TPP-67 ... TPP-67. Solid Door Refrigerator. TPP-67. True's pizza prep tables are ... Heavy duty PVC coated wire.
Aug 06, 2014 | True TPP-67 Commercial Refrigerator
Expose access to condensor to a true tpp-93 pizza prep table
Typically most True refrigerators you can access the condenser coils on the units either from the back or from the side of the unit.
Jul 08, 2013 | Refrigerators
I have a custom built Randell refrigerated sandwich prep table. The compressor is making a strange noise (rattles) and the temperature is too high (50 deg). The sticker on the motor reads: Model ...
If you were told to replace the entire compressor unit (condensing unit), the person diagnosed the compressor is most likely bad. Depending on the age of the unit, it is hard to tell if this is a good decision. Overall condition plays a role in the decision process as well.
Jan 18, 2018 | Randell Refrigerators
Bottom section not cooling but rail is cooling fine.
Hello Roytorboli,
I understand that your make table is not cooling the bottom. However the rail is cooling just fine.
The rail is cooling because it sets above the evaporator coil. The evaporator coil fan is not working you should be able to here it running when one of the bottom doors are open. The fan is located in the bottom compartment and has to be accessed threw there. You will take the front panel of the back plate off. One you locate the fan remove the wires and label and go to your local hardware store to purchase. Be sure to take the old one so that they can match it up.
Thank you for choosing
May 08, 2011 | Randell RAN-8383N Refrig Raised Rail Prep...
My pizza prep-table freezes everything. I think it might be the thermostat. Could I be right
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Apr 27, 2011 | True Refrigerated Sandwich Prep Table 72"...
Its freezing my product
It is freezing your food? What brand is this? Have you checked your climate setting?
Feb 16, 2011 | True TPP-93D-2 Pizza Prep. Table, 300...
I need full construction plans on how to build a pizza oven out of brick
this site has alot of different options with plans available for you
good luck sounds like a cool project
Jan 23, 2011 | Master Bilt Pizza Prep Table 20 cu ft...
I have a Randell 5ft Pizza Prep table that's not working correctly and was wondering if someone might be able to help me? The top rail is cooling like it should but the bottom storage area is NOT cooling...
This unit uses Thermostat/Solenoid Valve Combination's to control the temperature
1. Rail 2. Bottom Storage
The way it works is the thermostat senses the need for cooling and energizes the solenoid valve. This allows refrigerant flow which cools the area it is controlling. Once the thermostat is satisfied the contacts open and the solenoid is de-energized closing the valve. If the solenoid is bad, the valve remains closed, no refrigerant flow, warm unit.
Test the solenoid coil (two wires) to see if voltage is present either with a volt meter, or remove the coil off the valve and place a screwdriver (insulated) through the coil hole and you should feel the pull like an electro-magnet (what a coil is).
Dec 05, 2010 | Randell Refrigeration 60'' Refrigerated 2...
Why is there water pooling in my sandwich make up table? My reach in cooler, also?
During the cooling/freezing cycle condensation forms, this drips into a pan and then is evaporated by a heating element.
One of two things could be wrong.....
Your drip pan is clogged
your evaporator unit is bad
Hope this helps
Jun 22, 2010 | Randell Refrigeration 111'' Refrigerated 4...
Randell (84111NPCB) Logo
270 people viewed this question
Top Randell Refrigerators Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Are you a Randell Refrigerator Expert? Answer questions, earn points and help others
