Question about Kodak EASYSHARE Z1285 Digital Camera
How and where do I plug in my usb cable to my easy sharez1285 it doesnt seem to fit
My charger cord that came with my tablet won't go into the hole it's supposed to fit in because the hole seems to be off center!
At a guess, you've got a USB 2.0 Type B plug at the small end of your cable, and a USB 3.0 Type B socket (which is wider, and divided) on the tablet.
The plug WILL fit one side of the socket, and do its job!
(look up pictures of "USB 2.0 micro B" and USB 3.0 micro
B - I couldn't copy one for you. )
Oct 02, 2017 | Tablets & eReaders
HI, ihave a new phone, a LG GB230, and i want to put music on it. But my pc doesnt recognize my phone- it doesnt seem to "know" its connected to it, but i havnt got a programm to install the...
First, ensure that the USB cable is properly plugged into the phone and the computer, and ensuring the USB cable is not defective. NOTE. The phone must be plugged into the computer after it has powered up and all systems running. If your system still do not recognise the phone, you may have to download the phones' software from the internet.
Sep 13, 2011 | Cell Phones
I need a USB cable that connects from my camera (sony cybershot DSC-S60) to my computer. Where can I find one?
I have a better solution! (I had the same problem & searched for 2 months). Go to OfficeMax and buy a "Pocket Reader/Writer" for around $15. Plug in your memory stick and transfer your photos. Easy. Fits a lot of different cameras.
Jan 25, 2010 | Sony Cyber-Shot DSC-S60 Digital Camera
Run wd1600 via ide-usb problems
Just replace the case the drive is in. You can get them from stores that sell computer parts like Fry's Electronics. There are many online sources too.
Feb 08, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Cable for the sound card
mini-audio cable. shielded cable same type as headphone.
the plug should have 3 break with plasic insert in between.(stero) or single break (mon). it may or may not have color code on them.
Oct 14, 2008 | Zalman Tech Zalman USB 5.1 Channel...
USB cables
make sure you plug the small plug on your usb cable into your camera...easy..
the big plug on your usb cable must be plugged into your usb port on your computer. It can only fit in one way and not upside down. It will also fit into your network port, but this not correct port. If your usb plug fits into the port the right way up, and upside down, then it is the wrong port. If your computer is old, then it may not have a usb port.
Oct 08, 2008 | Cameras
USB cord Wont Fit?
The S730 has an uncommon USB input socket. You MUST use the USB connector which came with THIS camera.
Jan 07, 2008 | Samsung Digimax S730 Digital Camera
I can't seem to send images from my camera via cable or infrared
Simply get a cable that fits. The camera cable should be a standard USB A for the Computer- assuming the computer has USB or is it Sony and fitted with Fire-wire in which you will need an adaptor Fire-wire to USB
Jul 14, 2007 | Sony Cyber-Shot DSC-F1 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
19 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
